Drive shaft thick circlip https://www.ausmini.com/forums/viewtopic.php?f=2&t=85910 |
Author: | SuperCooper [ Sun Jun 01, 2014 8:05 pm ] |
Post subject: | Drive shaft thick circlip |
So my S driveshafts are missing the thick circlipthat butts up against the CV. Part no: 17H8597. Unavailable. Can you get them? Where? How do you put them on? Is it easier to find new shafts? Need some soon ish. Any advice appreciated.....thanks. |
Author: | MINImal effort [ Sun Jun 01, 2014 8:46 pm ] |
Post subject: | Re: Drive shaft thick circlip |
My question to this is : How do get them off an existing drive shaft ? Can they be re-used ? The alternative is these : http://www.minispares.com/product/Classic/Drivetrain/Driveshaft/C-BTA1267.aspx?0803 http://www.minispares.com/product/Classic/Drivetrain/Driveshaft/C-BTA1268.aspx?0803 |
Author: | SuperCooper [ Sun Jun 01, 2014 9:17 pm ] |
Thanks for the link. I had spotted those while looking for the circlips. I think the large circle on my shafts cracked in a few pieces and disintegrated . Also don't know how to get them off another shaft... |
Author: | Mick [ Sun Jun 01, 2014 9:21 pm ] |
You don't mean the retention detent clips? They're made of thin piano wire and can be made yourself. |
Author: | SuperCooper [ Sun Jun 01, 2014 9:23 pm ] |
No not the thin clips. The larger clip closer to the inside end of the spline. |
Author: | drmini in aust [ Sun Jun 01, 2014 9:37 pm ] |
I've got a spare shaft here, I'll suss the clip out in the morning. |
Author: | SuperCooper [ Sun Jun 01, 2014 9:40 pm ] |
drmini in aust wrote: I've got a spare shaft here, I'll suss the clip out in the morning. Thanks doc. Is there a difference between Cooper S shafts and non S shafts? Eg higher spec metal/hardening process? Can I use standard shafts? |
Author: | drmini in aust [ Sun Jun 01, 2014 9:58 pm ] |
Cooper S shafts are higher spec steel but I used std 850 ones on my 1st 1220>1275 Mini, just put the hardy spicer joints onto the splines. S ones have a raised diameter part way along the shaft, also their length is very slightly different. But std shafts do work OK, particularly on a road car. If rallying I'd like S ones at least. |
