Can you undo door guide block without losing backing plate
https://www.ausmini.com/forums/viewtopic.php?f=2&t=85972
Author:  Flute [ Thu Jun 05, 2014 4:47 pm ]
Post subject:  Can you undo door guide block without losing backing plate
I have started the resto.
Just wondering if I can undo these screws without the backing plate falling down? It doesn't seem to have a captive backing and you cant get inside if anything drops. Thanks.
Author:  Mick [ Thu Jun 05, 2014 4:51 pm ]
Post subject:  Re: Can you undo door guide block without loosing backing pl
The back plate is captive and will not move very far at all. You will easily get the screw back in again.
Author:  drmini in aust [ Thu Jun 05, 2014 4:51 pm ]
It's 20 years since I replaced mine but I'm pretty sure the tapped plate inside is captive.
Author:  Scoop [ Thu Jun 05, 2014 7:03 pm ]
Post subject:  Re: Can you undo door guide block without losing backing pla
It is on my deluxe.
Author:  Flute [ Thu Jun 05, 2014 8:24 pm ]
Thanks, loosened the screws and realized the back was moving so stopped in case it fell but then thought if it can then how did they put it there. Better safe than sorry, thanks for replies.
