Gearbox - Stripped Third Motion Retainer Hole https://www.ausmini.com/forums/viewtopic.php?f=2&t=86091 |
Author: | bnicho [ Sat Jun 14, 2014 6:43 pm ] |
Post subject: | Gearbox - Stripped Third Motion Retainer Hole |
Hi, I was working on rebuilding my Moke's gearbox today (late A+). Everything was going swimmingly until I tightened up the bolts on the third motion shaft retainer. The lower bolt hole that holds the layshaft and reverse shafts in place stripped. ![]() I've already pulled the layshaft and reverse idler shaft out. It looks like I can drill the hole out and heilcoil it back to 5/16 UNF or UNC without too much problem. I will have to cut down the helicoil before fitting though, as the gearbox web is rather thin at this place and I don't want the end of the helicoil hanging out the back and possibly fouling on the reverse idler. Can anyone see an issue with this? Thanks, |
Author: | Mick [ Sat Jun 14, 2014 6:53 pm ] |
Post subject: | Re: Gearbox - Stripped Third Motion Retainer Hole |
Nope, but use a little loctite on the shortened helicoil to stop it driving through or moving. Helicoils are superb. |
Author: | drmini in aust [ Sat Jun 14, 2014 7:20 pm ] |
I have done this mod many times: The stripped hole is now 5/16" dia = tapping size for 3/8" UNC. Tap it out to 3/8 UNC and drill the bearing retainer and layshaft keep plate 10.0mm for clearance. Don't bother with a helicoil in there, the thread is too short to be reliable. You will not strip a 3/8 UNC bolt, but ensure it's not too long or it will hit the reverse gear idler. Don't bother with a locktab, use a new 3/8 spring washer, and Loctite on the threads if you like. |
