It is currently Sat Aug 23, 2025 6:18 pm
 Post subject: Tap size?
PostPosted: Fri Jun 20, 2014 8:09 pm
Hello all,
I'm in the process of getting the mini on the road and I've hit a bit of a snag. A small one but a snag no the less. After I removed what was left of the coolant bypass pipe that sits in the cylinder head, i've found that the new pipe won't go in. I've had a look at the thread and it looks undamaged, just covered in crud and needs a thread tap put through it. Could someone tell me what sized tap I need please?
Simo
 Post subject: Re: Tap size?
PostPosted: Fri Jun 20, 2014 8:50 pm
If I recall it's a 5/8 16TPI and is a special tap, same as the end of the crank shaft.
PostPosted: Fri Jun 20, 2014 9:13 pm
Just checked it is 5/8 16n
I would use a small wire brush in a drill, or a pick
Way cheaper than the correct tap as they are exspensive.
PostPosted: Fri Jun 20, 2014 10:01 pm
I put a 5/8-18 UNF tap in there (it's only got about 4 threads), then machine up a brass fitting. No more rusting...
PostPosted: Sat Jun 21, 2014 7:34 am
Excellent idea Doc, then you won't have to replace it every 25 years. :lol:
Can't you just blank them ala Rover style? Don't shoot me, just asking.
PostPosted: Sat Jun 21, 2014 8:05 am
Haha.
Every head I buy/acquire seems to be 40 years old, nothing much left there to unscrew so I stick a 9/16" drill in it then peel the threads out with the tap. I object to paying $10 or more for new adaptors with built in rust capability, so I make brass ones.
Sure you can plug it, I'd drill one or two 3mm holes in the thermostat to provide a little circulation during warmup.
The Rover heads are plugged but have a sandwich plate under the thermostat instead. I don't know how that is plumbed in the system- there ain't no Rover Minis around here.
PostPosted: Sat Jun 21, 2014 8:23 am
Yeah, I think it's still by passes through the manifold heating section. Rover's have the most hiddius hose arrangement.
Users browsing this forum: timmy201 and 78 guests
