It is currently Sun Jul 27, 2025 1:39 am
PostPosted: Sat Jun 28, 2014 7:58 pm
I am struggling to undo the drain plug on my fuel tank, just not enough room to get my hand and a spanner in.
What tool should I use? Do I need a specialist tool? Or do I just need to sweat, swear and bleed a bit more?
Stu.
PostPosted: Sat Jun 28, 2014 8:00 pm
It will come out usually with the drain attached. Undo the strap completely and wriggle the tank around.
PostPosted: Sat Jun 28, 2014 8:10 pm
You need a tube spanner which is long enough to reach over the long drain tube to reach the nut section.
PostPosted: Sat Jun 28, 2014 11:07 pm
Thanks guys, round 2 in the morning.
PostPosted: Sun Jun 29, 2014 5:02 pm
Or do what I did. Plan in replacing the plug anyway as it will probably be rusted. That leaves you free to use a pair of side cutters the trim the tube to to the desired length. If you still have problems a standard socket will now fit over the plug.
PostPosted: Sun Jun 29, 2014 6:34 pm
drive a screwdriver up the tube and undo with multiegrips
if the tube snaps off , then you can get a socket over the nut
I think John at Minikingdom on line still has new old stock of these drain plugs
Mark
