for what you want to do use polyester resin not as expensive as epoxy also some epoxy resin not real good for health and ideally must be used in well ventilated work areas
poly easier to use
clean up using acetone
if making a plug and then a mould to pull a part from you will need to wax all the bits with a good quality canubra wax .do not use a silicone product not the best of working pals. the mould release agent is PVA also known as poly vynal alcohol
the catalyst
is MEKP this is not good stuff wear safety glasses do not get it near your eyes or mouth
there are some good books to be had read up on the subject and follow the directions.
it can be done well if you take your time do not rush things think it all out
practise also helps do things in small bits and hold back on the grand plans until you have worked it through.
have been working with fibre reinforced plastics for some years best of luck
