Indicator Cancellation https://www.ausmini.com/forums/viewtopic.php?f=2&t=86215 |
Author: | Hanra [ Thu Jun 26, 2014 10:12 am ] |
Post subject: | Indicator Cancellation |
I remember many years ago (1997) I had an issue with my indicators not self cancelling due to the mechanism being worn, I think the little spring was flogged or stretched or missing. Anyways, for what ever reason I removed the small screw or bolt? from the steering colum that allows the indicators to cancel. Does anyone know what size this is? Does anyone have a spare I could buy? Does anyone have a photo of what it looks like? Ive bought a new indicator mechanism and would like this function to work. |
Author: | Hanra [ Thu Jun 26, 2014 3:15 pm ] |
Post subject: | Re: Indicator Cancellation |
Item 18 21A2080 Actuator pin for indicators - Non steering lock MK1/2 ![]() |
Author: | Morris 1100 [ Thu Jun 26, 2014 6:33 pm ] |
Author: | winabbey [ Thu Jun 26, 2014 6:54 pm ] |
It's a small bolt with a square head. They are available new from Somerford (see below) but surely someone on here or one of the Mini parts businesses has a spare inner steering column for wrecking. Otherwise grind a bolt head square to suit. https://www.somerfordmini.co.uk/eshop/i ... ts_id=5807 |
Author: | Hanra [ Thu Jun 26, 2014 8:14 pm ] |
Yep thats how I remember it. I reckon I put it in a safe place back in the late 90s and now that safe place dosnt exist anymore. Had a search through my boxs of nuts/bolts spread out all over the garage floor.... no luck.... I have no idea what thread it even is? And I recall that lock nut on there also. If some one had a spare, Id gladly purchase it and cover freight costs. |
Author: | Hanra [ Fri Jun 27, 2014 10:13 am ] |
Ive put up a wanted ad. viewtopic.php?f=9&t=86223 |
Author: | Convertible Mini [ Fri Jun 27, 2014 1:15 pm ] |
Make sure you have the self cancelling screw adjusted to the correct height or you will damage the switch. |
