It is currently Mon Aug 04, 2025 3:18 am
 Post subject: Indicator Cancellation
PostPosted: Thu Jun 26, 2014 10:12 am
I remember many years ago (1997) I had an issue with my indicators not self cancelling due to the mechanism being worn, I think the little spring was flogged or stretched or missing.
Anyways, for what ever reason I removed the small screw or bolt? from the steering colum that allows the indicators to cancel.
Does anyone know what size this is? Does anyone have a spare I could buy? Does anyone have a photo of what it looks like?
Ive bought a new indicator mechanism and would like this function to work.
PostPosted: Thu Jun 26, 2014 3:15 pm
Item 18
21A2080 Actuator pin for indicators - Non steering lock MK1/2
PostPosted: Thu Jun 26, 2014 6:33 pm
PostPosted: Thu Jun 26, 2014 6:54 pm
It's a small bolt with a square head. They are available new from Somerford (see below) but surely someone on here or one of the Mini parts businesses has a spare inner steering column for wrecking. Otherwise grind a bolt head square to suit.
https://www.somerfordmini.co.uk/eshop/i ... ts_id=5807
PostPosted: Thu Jun 26, 2014 8:14 pm
Yep thats how I remember it. I reckon I put it in a safe place back in the late 90s and now that safe place dosnt exist anymore. Had a search through my boxs of nuts/bolts spread out all over the garage floor.... no luck....
I have no idea what thread it even is? And I recall that lock nut on there also.
If some one had a spare, Id gladly purchase it and cover freight costs.
PostPosted: Fri Jun 27, 2014 10:13 am
Ive put up a wanted ad.
viewtopic.php?f=9&t=86223
PostPosted: Fri Jun 27, 2014 1:15 pm
Make sure you have the self cancelling screw adjusted to the correct height or you will damage the switch.
"Let us remove your "SHORTS"
