Got my brake pipes from John on Friday.
Decided to fit all the parts up. What could go wrong eh !
Worked on the left hand one as I have better access on that side of the car in the garage.
Fitted the slave cylinder and retaining clip. Installed the brake pipe and nipped it up with the correct spanner.
I installed my new handbrake lever first, then fitted the bottom spring to the two shoes and slipped them into place on the handbrake lever but not onto the slave cylinder.
Fitted the top spring and then pulled the shoes into place on the slave cylinder first and then onto the adjuster at the top. All done, easy peasy.
Admiring my work I realised I had the rear shoe un upside down
Pulled it apart and reassembled and all was good.
Slipped the drum on and found out that one shoe was rubbing.
Off with the drum and the rear shoe was rubbing at the top of the lining. I couldn't move the shoe down as the handbrake pushrod was sitting hard on the top of the cylinder. Bugger, wrong one on the wrong side. You have to fit the one that has the lever under the push rod to allow the brake shoe to sit a bit lower. All reassembled again but there was still a slight scraping sound.
Off with the brake drum again and found out that the bottom spring was rubbing on the body of the hub. Dismantled it all AGAIN !
All reassembled and this time with the straight part of the spring between the two coiled ends at the bottom and all was OK.
Having made every mistake you can I threw the other side together in seconds.
I adjusted the adjusters up all the way to centralise the shoes and then bled the brakes (one man kit).
Loosened off the adjusters until the drum rotated smoothly.
Loosened off the handbrake cables at the handle in the car until the clevis lined up with the hole in the lever on the backing plate and fitted the pin, washer and split pin.
3 clicks and the wheels can be rotated by hand, 4 clicks and they are Locked solid.
There only simple but you still have to get it all round the right way.
Learnt a lot and happy with the End result.
