justminis wrote:
The CV's are different between drum brakes and disc brakes, disc CV's are bigger. There are really only 2 different types of axles and either will work on either type of CV. There are axles that suit the later pot joints, typically on rod change gearboxes, and then there are those that suit the earlier large rubber or hardy spicer (Cooper S) type of universal joints typically found on remote change gearboxes. Depends on what type you have now, e.g. you can swap the drum brakes to disc brakes by using your existing axles but change the CV. As you're in Brisbane, best bet would be to contact one of the local mini businesses.
hi,
I do not want to runt he disk's on this car, they are staying under the other.
Id rather stick with the pot join style over uni joins/hardy spicer.
is there a cheap way to do it? minisport if i add up the parts i need to build the shafts from them ill be needing a mortguage!
i might give Mr Automotive a call see if they have what I need and how many organs they want for them. .
Leroy.
1967 Mini Deluxe bucket of rust and mismatched parts powered by a 1360cc and a destroyed gearbox missing second gear
