It is currently Sun Aug 17, 2025 12:38 pm
PostPosted: Mon Jul 07, 2014 12:14 pm
Hey guys, are the starter motors Bendix type?
71 Clubman 1100
PostPosted: Mon Jul 07, 2014 12:42 pm
Yes, all Oz Minis got a Lucas bendix type starter.
There are other options- for example,
1.6L Gemini (file the mounting holes to fit),
Bosch planetary geared starter from `convertible mini' on here.
Both these starters are pre-engaged type.
[edit] There are also hi-torque starters similar to this one at Mini Mania, USA-
Minis Plus once sold a similar one, not sure if they still do these days.
Last edited by drmini in aust on Mon Jul 07, 2014 4:18 pm, edited 1 time in total.
PostPosted: Mon Jul 07, 2014 3:30 pm
I contacted GM for the Gemini starter cranking torque, it turns out the mini Lucas had a specified higher cranking torque. Pity about the Gemini one, I'd bought and modded.
I guess it's always prudent to have a well charged battery and clean all the earth points.
PostPosted: Mon Jul 07, 2014 3:44 pm
Gemini starter pulls less power, true, but it has less drive friction, because the drive pinion is not overhung way out past the shaft bush.
And, being pre-engaged, it does not throw itself out of mesh and go `whirrrrr!!' if the motor gives an isolated kick.
You can just hold the key on until the bugger starts. :P
[edit] It's used standard on 1.6L Isuzu motors, and overseas on 1.8L ones I think.
There are Chinese copies sold here, but I had problems with the solenoid sticking on, so an Isuzu/GM original is better, IMO.
A downside of the Gemini is it is in the road of a Cooper S oil cooler, unless that's moved >>.
PostPosted: Mon Jul 07, 2014 4:31 pm
Ok no worries thanks for the help! :)
71 Clubman 1100
Users browsing this forum: No registered users and 353 guests
