It is currently Sat Aug 16, 2025 1:51 pm
 Post subject: Loose fan belt!!!!
PostPosted: Thu Jul 17, 2014 6:03 pm
Hi everyone
So it seems to be that my fan belt keeps coming loose. I'm assuming it would be the alternator maybe moving? I don't really know where to go because all the bolts are tight and the sleeve in the top bracket is firm..
It's gotten sorta progressively worse, could go a few days of driving with it tight, then a day, half a day. Now it's just done 20km's and needs adjusting again or it squeals! argh
please help me
Thanks
James
 Post subject: Re: Loose fan belt!!!!
PostPosted: Thu Jul 17, 2014 6:14 pm
Is the 9/16 nut that holds adjusting arm to the engine front plate tight
The alternator is held on with three bolts and one nut. Are they all there.
PostPosted: Thu Jul 17, 2014 6:16 pm
You havent got worn pulleys have you? Belt going in the V to much.
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Thu Jul 17, 2014 6:22 pm
Yep they're all there, and they're all new bolts/nuts
And yes the 9/16 nut is done up nice and tight
Well I'd hope not, the engine is new, the water pump pulley is new and it's a new alternator
PostPosted: Thu Jul 17, 2014 6:50 pm
Is it actually going loose or is it just squealing a lot? Try rubbing some soap on it to stop the squeal.
PostPosted: Thu Jul 17, 2014 6:53 pm
It's definitely going loose. You can feel quite a difference in the tension
PostPosted: Thu Jul 17, 2014 6:56 pm
Are you running out of adjustment? Maybe a dodgy belt and is stretching???? Just a thought.....
1964 smooth roof panel van
1967 Mk 1 X-Police cooper s
1970 mini k
1975 leyland
PostPosted: Thu Jul 17, 2014 6:58 pm
I originally thought it may just be stretching (as everything is new) but the belt has 600km on it now and still doing it. It still has lots of adjustment left on it though
PostPosted: Thu Jul 17, 2014 7:04 pm
Mayb mark the bolts and adjustment with a marker and see if they move ??
64' 850 1275cc
PostPosted: Thu Jul 17, 2014 7:09 pm
Genius idea! I'm going to try that
PostPosted: Thu Jul 17, 2014 7:17 pm
Do the pulleys have the same section to match the belt.
Can you compare them to the old ones.
PostPosted: Thu Jul 17, 2014 7:20 pm
Yeah they seem to. I'm using the larger water pump pulley with the 70amp alternator. Side by side they look the same :\
PostPosted: Thu Jul 17, 2014 7:30 pm
The only thing left is the belt. Is it a good quality one from a good manufacturer
PostPosted: Thu Jul 17, 2014 7:44 pm
http://minispares.com/product/Classic/E ... lassic/Fan Belt.aspx
This is the belt I bought for it. To be totally honest I'm not sure if they're good or not
PostPosted: Thu Jul 17, 2014 7:59 pm
I would buy a belt from Oz. Take a pulley with you and the belt with you for the length.
I am not a fan of cogged belts. Find a vee one.
Fingers crossed it sorts your problem.
Users browsing this forum: No registered users and 370 guests
