It is currently Sun Jul 20, 2025 12:38 am
 Post subject: Removing panels
PostPosted: Thu Jun 12, 2014 7:32 pm
Hi guys and girls I'm looking at removing my two front guards on my 1977 Ls mini is there a site or instructions on how to do this at all? I have pretty much got the car striped
This is my mini
 Post subject: Re: Removing panels
PostPosted: Thu Jun 12, 2014 9:00 pm
They're spot welded on in a lot of places. Why do you want to remove them?
PostPosted: Thu Jun 12, 2014 9:05 pm
Both gaurds have heaps of bog in them and have been repaired before so am thinking it would be easier to just take them of and put the two new ones on that I have got
PostPosted: Thu Jun 12, 2014 9:40 pm
There are heaps of spot welds along all the joins. Buy a good spot weld drill and start drilling. You will have to remove the front seam cover to access those spot welds.
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Thu Jun 12, 2014 9:42 pm
I though that just want to look at a video or read something that that shows you what to do
PostPosted: Thu Jun 12, 2014 9:47 pm
All the flat edges on your new guards will be where the spot welds are. When you drill the spot welds, avoid going to deep. You only want to go through the first skin. I think with a clubby you might need the headlight panel as well, not 100% though. I've only done round nose guards.
5/72 Clubman Gt
PostPosted: Thu Jun 12, 2014 9:51 pm
Oh ya cool thanks for that, I will see how I go wish me luck
PostPosted: Fri Jun 13, 2014 3:56 pm
To remove a bad panel cut the panel off with a cutting disc close to the welds and then trim the spot welds off with a grinder.
PostPosted: Sun Jun 15, 2014 10:44 pm
Which size of spot weld drill bit would be the best for the welds on minis? 8mm?
Cooper S Mk2
Cooper S Mk1
PostPosted: Sun Jun 15, 2014 10:51 pm
Photo links updated by moderator
PostPosted: Sun Jun 15, 2014 10:53 pm
Its off! Looks good.
I've used spot weld drill bits, and while they're not bad, they don't always get all the weld area, so leave a little hanging. You also tend to go through to the next panel a little too easily, but they're great in places where you can't get a grinder.
PostPosted: Sun Jun 15, 2014 10:57 pm
I'm not sure what size it would be I think it was 6mm drill bit
PostPosted: Mon Jun 16, 2014 11:28 am
sorry for the off-topic and if others get on the bandwagon, but I can't imagine going to that much effort and not pulling the subframes out and doing the engine bay and underside as well
PostPosted: Mon Jun 16, 2014 8:10 pm
I use a spot weld drill that has a step on it. When you drill through the first skin, the step starts to cut. When you see this you stop drilling as you know the depth should be enough. Wurth sell them I think. I got mine from Forch #55151075 is the product code. Really good spot weld drill.
5/72 Clubman Gt
PostPosted: Mon Jun 16, 2014 9:06 pm
I was thinking of doing the front subframe as well but need to wait till I have moved house as I'm running out of space to put stuff plus still need to cut out the rust holes
