It is currently Fri Jul 18, 2025 9:08 pm
PostPosted: Thu Aug 07, 2014 9:12 pm
Hi all
i am currently trying to source gaskets etc.. and when i come up to the boot and door hinge gaskets. Karcraft had paper and rubber ones to choose from and i have no idea which one will be better in the long run. so i am hoping that someone has had previous experiences and could help me not to make any wrong decisions.
cheers hayden
Present
- 1968 Morris Mini Deluxe- resto
-1979 Leyland Moke
-2007 R56 MINI Cooper
Past
-1964 Morris Mini Van
-1965 Morris Mini Van
-1961 Morris Mini 850
PostPosted: Thu Aug 07, 2014 9:29 pm
The hard paper ones are the better one's in my opinion. The rubber one's tend to pop out the sides when bolts are tightened enough to hold hinge etc.
PostPosted: Thu Aug 07, 2014 9:35 pm
Go to Supercrap and buy some gasket paper and a sharp scalpel. Cut your own and save big $$$$
PostPosted: Fri Aug 08, 2014 7:36 am
Plastic, cut from an ice cream tub.
The paper holds water, and the rubber shrinks, particularly now it is mostly all imported natural rubber from the far east.
PostPosted: Fri Aug 08, 2014 11:48 am
and you can even select the colour that you want between different ice cream tubs and oil containers etc
PostPosted: Fri Aug 08, 2014 11:50 am
Ha ha... I can see it now at the supermarket "do you have any ice cream to colour match my Mini?"
PostPosted: Fri Aug 08, 2014 12:07 pm
That's not as silly as it sounds given the gasket edges were painted at the factory, because the panels were hung prior to painting.
Otherwise just use some body coloured paint on the gasket edges prior to assembly. Much better looking result.
PostPosted: Fri Aug 08, 2014 1:11 pm
+1 On the Ice Cream container. As a bonus, you get to eat a tub of Ice cream! It's win win really.
Keels.
-Wasabi
1972 Clubman - Daily Driver
1962 850 - EW1 Powered
PostPosted: Fri Aug 08, 2014 1:48 pm
Make sure it's a big tub though - you need long gaskets! And remember the hinges are all different, so don't mix them up.
PostPosted: Fri Aug 08, 2014 4:25 pm
But I like mixed ice cream?
PostPosted: Fri Aug 08, 2014 7:41 pm
Hmm, maybe I could buy it in 20ltr buckets. Only proplem is, I'll have to repaint my mini Neopolitan.
PostPosted: Sat Aug 09, 2014 1:38 pm
I used plastic ones years ago, I got them from Brikworx Adelaide when Steve was doing classic Minis. They have raised edges so the hinge sits inside them, really well made things. I put them on about 8 years ago and they are still as good as new plus it was an every day car for a few years.
TOO MANY MINIS AND NOT ENOUGH TIME
