su piston and needles https://www.ausmini.com/forums/viewtopic.php?f=2&t=86648 |
Author: | drjbeam [ Fri Jul 25, 2014 8:19 pm ] |
Post subject: | su piston and needles |
Can a run a fixed piston and needle in a su that had a biased piston and needle |
Author: | Mick [ Fri Jul 25, 2014 8:30 pm ] |
Post subject: | Re: su piston and needles |
I converted a pair of Twin 1.5's recently from swinging needles and waxstats. You need to buy an adaptor bush to fix the needle. Only a couple of dollars each. viewtopic.php?f=2&t=83695&hilit=twin+1.5 |
Author: | drjbeam [ Fri Jul 25, 2014 9:57 pm ] |
Cant i just drop in a fix needle piston with the fixed needle in it already Im playing around with a hs2 1 1/4 |
Author: | drmini in aust [ Fri Jul 25, 2014 10:19 pm ] |
Yes you can, but you should use the bell that came with that piston. |
Author: | simon k [ Fri Jul 25, 2014 10:54 pm ] |
just make a paste with some ajax and water and hone them into each other a bit. |
Author: | drjbeam [ Sat Jul 26, 2014 6:15 pm ] |
Ok thanks |
Author: | 1071 S [ Mon Jul 28, 2014 8:38 pm ] |
Why would you risk messing up 2 carbs when you can get the correct needle mount for a few dollars? Cheers, Ian |
