compression test
https://www.ausmini.com/forums/viewtopic.php?f=2&t=86652
Author:  Diesel27 [ Sat Jul 26, 2014 7:05 pm ]
Post subject:  compression test
just carried out a comp test and only have 120 psi, would have expected more?
Author:  MiniVLT [ Sat Jul 26, 2014 7:42 pm ]
Post subject:  Re: compression test
Did you do the test with a warm or cold engine?
Author:  Morris 1100 [ Sat Jul 26, 2014 7:44 pm ]
120 is pretty normal on a stock motor.
Author:  mini_mad_matt [ Sat Jul 26, 2014 8:45 pm ]
I wouldn't be particularly concerned unless they varied a lot from cylinder to cylinder
Author:  Monaco [ Sat Jul 26, 2014 9:36 pm ]
Depends on the gauge too. It is more the variance across the cylinders that is important. Did you have your foot flat on the accelerator pedal?
Author:  Scoop [ Sat Jul 26, 2014 9:41 pm ]
How does the accelerator pedal matter?
Author:  Morris 1100 [ Sat Jul 26, 2014 9:48 pm ]
You need to accelerator open to get a proper compression reading.
It is hard to get compression from a vacuum.
Author:  Convertible Mini [ Sun Jul 27, 2014 6:06 am ]
You need Air to compress air!
Author:  Scoop [ Sun Jul 27, 2014 10:07 am ]
So your saying no air enters the engine if you dont have the accelerator open. Or just not enough for the compression test.
Author:  Irish Yobbo [ Sun Jul 27, 2014 11:47 am ]
The butterfly is almost closed to restrict air down to idle speed, so less air.
For an accurate reading you will want a strong battery and a foot on the accelerator. You're supposed to do it with a warm engine too.
If you get a low reading, put some oil in the cylinder and try again. If the compression jumps up dramatically, your rings are worn.
I would say that 120 is a little on the low side, but it's not reconditioning territory yet.. A new modern engine (which has a good starting system and higher compression ratio) will read about 200psi, my mini reads ~145psi (998 with no mods).
Author:  Diesel27 [ Sun Jul 27, 2014 12:34 pm ]
cheers Irish that is what I wanted to hear.
120 compared with 145,
Author:  smac [ Sun Jul 27, 2014 5:08 pm ]
Which could just be the difference between two gauges.
Author:  Morris 1100 [ Sun Jul 27, 2014 5:23 pm ]
Could almost be the difference between brands of head gaskets. :lol:
Author:  MiniBob [ Fri Aug 01, 2014 1:03 pm ]
Compression is also reliant on good valve seal / adjustment.
If there is a bit of carbon present or the tappets need doing then the figure will be lower.
