mini matic? https://www.ausmini.com/forums/viewtopic.php?f=2&t=86670 |
Page 1 of 2 |
Author: | SuperCooper [ Sun Jul 27, 2014 9:15 pm ] |
Post subject: | mini matic? |
Got a yma2s4 this arvo but engine no plate is 99hh119/H559. Is that correct eng no for an auto? Thanks..... |
Author: | Kennomini [ Sun Jul 27, 2014 9:25 pm ] |
Post subject: | Re: mini matic? |
Manual blocks can not fit on auto gearboxes so if the engine is fitted to a auto box then it's an auto. |
Author: | SuperCooper [ Sun Jul 27, 2014 9:27 pm ] |
Eng in car is an 1001...... clubby 1100? The 99hh no. Is on the id plate......id have thought 99hh would be a deluxe 998 motor? |
Author: | Morris 1100 [ Sun Jul 27, 2014 9:37 pm ] |
99H119/H559 is a Matic motor. They were fully imported so they use the UK prefix codes. The Deluxe had 9YA/Ta/H motors. |
Author: | SuperCooper [ Sun Jul 27, 2014 9:45 pm ] |
Oh ok......thanks morris 1100.... |
Author: | drmini in aust [ Sun Jul 27, 2014 10:58 pm ] |
All the MiniMatics (except maybe the earliest) had a 99H/119/H motor I think. Mine is 3/70 and had one. Note the Mk2 Matics (with the K dash) are YA2S5, not YA2S4. |
Author: | John Sneddon [ Mon Jul 28, 2014 10:45 am ] |
Your car should be a YMA2S4 approximately 1800 based on the data I have. Does it have a model stamping in the radiator shroud? |
Author: | SuperCooper [ Mon Jul 28, 2014 11:08 am ] |
Body No is 2014. |
Author: | Chux [ Mon Jul 28, 2014 11:49 am ] |
Morris 1100 wrote: 99H119/H559 is a Matic motor. They were fully imported so they use the UK prefix codes. The Deluxe had 9YA/Ta/H motors. drmini in aust wrote: All the MiniMatics (except maybe the earliest) had a 99H/119/H motor I think. Mine is 3/70 and had one. Note the Mk2 Matics (with the K dash) are YA2S5, not YA2S4. Is mine one of the really early ones or something? ![]() Untitled by Chux007, on Flickr |
Author: | John Sneddon [ Mon Jul 28, 2014 2:29 pm ] |
1194 is early being the 694th matic built |
Author: | Morris 1100 [ Mon Jul 28, 2014 5:08 pm ] |
I think they built around a thousand cars with the first batch of imported engines, these numbers seem to be issued randomly like the Cooper S, low numbers cars have high numbered engines and vice versa. Somewhere between car 1519 and 1735 they changed from the 9AN/AH/ engines to the 99H/119/H engines. I think they changed the codes in the UK plants after Leyland took over around the middle of 68. |
Author: | Hanra [ Mon Jul 28, 2014 5:59 pm ] |
Mine is Engine number: 99H119/H/365 Body number: 1606 |
Author: | Morris 1100 [ Mon Jul 28, 2014 6:17 pm ] |
That narrows it down further. And it also helps date the cars (I just need the date that the UK changed the code!). Some people try to say that 99H119/H/ means mk2 Matic. |
Author: | SteveOB [ Mon Jul 28, 2014 6:38 pm ] |
hmmm, what would mine be then please Morris 1100? Engine No: 99H119H1009 Body No: 2497 cheers |
