Is there a speedo guru out there?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=86708
Page 1 of 2
Author:  bamnfi [ Thu Jul 31, 2014 4:47 pm ]
Post subject:  Is there a speedo guru out there?
With a change in diff ratio my speedo has me at about 35mph when I know I am ranging down the freeway at at least 100kph.
With the re-build a different diff ratio was used.
Is there any way to get the speedo re-calibrated to be within cooee of real speed?
Author:  Mackie [ Thu Jul 31, 2014 5:53 pm ]
Post subject:  Re: Is there a speedo guru out there?
Howard's instruments in Heidelberg is ment to be awesome..I rang up last month about $220-$250 for recalibration of speed and distance..
Author:  bamnfi [ Thu Jul 31, 2014 6:57 pm ]
Brill. Thanks Mackie. That's pretty close to where my car got de-rusted by Geoff at A Grade Panels.
Author:  drjbeam [ Thu Jul 31, 2014 7:25 pm ]
Get a navman or simular for half the price
Author:  bamnfi [ Thu Jul 31, 2014 7:32 pm ]
Sheesh, that ain't so sexy. Effective sure, but not quite the look I want.
Author:  MiniVLT [ Thu Jul 31, 2014 8:03 pm ]
Why do you want to recalibrate the speedo when all you should have to do is change the speedo drive gear ratio?
http://www.guess-works.com/Tech/ratio.htm
http://www.guess-works.com/Tech/speedo.htm
Check out these, they should put you in the ball park!
Cheers Shane
Author:  Mackie [ Thu Jul 31, 2014 8:04 pm ]
Same prob I have. I got a mk1 silver speedo in mph kinda annoying converting to kph in my head but wana keep the silver speedo.. Haha can't win. Mine reads 75-80mph at 100kph haha
Author:  drjbeam [ Thu Jul 31, 2014 8:06 pm ]
It can be taken off the window my speedos +20 kmh out when over a 100 kmh speedos reading 120 gps reading 100.
Author:  MiniVLT [ Thu Jul 31, 2014 8:20 pm ]
Guys, the speedo drive gears are in the gearbox and can be altered / changed without removing the engine. Changing the ratios will get your speedo reading correctly!
Read the info at guess-works!
Cheers Shane
Author:  Mackie [ Thu Jul 31, 2014 8:22 pm ]
I've been roughly going off the revs.. I'm either doing 100 or 80 in my area.. GPS app on the iphone helps too.
Author:  peterb [ Thu Jul 31, 2014 9:08 pm ]
You used to be able to get a sticker that went on outside of glass, had kph markings in right places.
Author:  winabbey [ Fri Aug 01, 2014 4:53 pm ]
The main reason Howard's Instruments is referred to is because the owner, Rodger Howard is very Mini sympathetic. He has a garage full of vans, S's and other versions and is fairly active in the Mini scene. Not cheap but he does quality work.
Author:  bamnfi [ Fri Aug 01, 2014 4:56 pm ]
Yup, went and met the man today. Certainly knows his stuff and has some tasty toys.
Author:  Flute [ Fri Aug 01, 2014 10:13 pm ]
He has mine too at the moment, I have been there a few times now for different instruments. Great bloke, great business, highly recommended.
Author:  Diesel27 [ Sat Aug 02, 2014 10:39 am ]
Cant remember the last time I viewed the speedo?
