It is currently Wed Jul 23, 2025 1:35 am
 Post subject: compression test
PostPosted: Sat Jul 26, 2014 7:05 pm
just carried out a comp test and only have 120 psi, would have expected more?
It's easy once you know how.
 Post subject: Re: compression test
PostPosted: Sat Jul 26, 2014 7:42 pm
Did you do the test with a warm or cold engine?
PostPosted: Sat Jul 26, 2014 7:44 pm
120 is pretty normal on a stock motor.
PostPosted: Sat Jul 26, 2014 8:45 pm
I wouldn't be particularly concerned unless they varied a lot from cylinder to cylinder
PostPosted: Sat Jul 26, 2014 9:36 pm
Depends on the gauge too. It is more the variance across the cylinders that is important. Did you have your foot flat on the accelerator pedal?
PostPosted: Sat Jul 26, 2014 9:41 pm
How does the accelerator pedal matter?
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Sat Jul 26, 2014 9:48 pm
You need to accelerator open to get a proper compression reading.
It is hard to get compression from a vacuum.
PostPosted: Sun Jul 27, 2014 6:06 am
You need Air to compress air!
"Let us remove your "SHORTS"
PostPosted: Sun Jul 27, 2014 10:07 am
So your saying no air enters the engine if you dont have the accelerator open. Or just not enough for the compression test.
5/72 Clubman Gt
PostPosted: Sun Jul 27, 2014 11:47 am
The butterfly is almost closed to restrict air down to idle speed, so less air.
For an accurate reading you will want a strong battery and a foot on the accelerator. You're supposed to do it with a warm engine too.
If you get a low reading, put some oil in the cylinder and try again. If the compression jumps up dramatically, your rings are worn.
I would say that 120 is a little on the low side, but it's not reconditioning territory yet.. A new modern engine (which has a good starting system and higher compression ratio) will read about 200psi, my mini reads ~145psi (998 with no mods).
PostPosted: Sun Jul 27, 2014 12:34 pm
cheers Irish that is what I wanted to hear.
120 compared with 145,
PostPosted: Sun Jul 27, 2014 5:08 pm
Which could just be the difference between two gauges.
http://www.mini-hb.co.nz
PostPosted: Sun Jul 27, 2014 5:23 pm
Could almost be the difference between brands of head gaskets. :lol:
PostPosted: Fri Aug 01, 2014 1:03 pm
Compression is also reliant on good valve seal / adjustment.
If there is a bit of carbon present or the tappets need doing then the figure will be lower.
