mini service km list https://www.ausmini.com/forums/viewtopic.php?f=2&t=86718 |
Author: | drjbeam [ Fri Aug 01, 2014 10:02 am ] |
Post subject: | mini service km list |
http://www.allpartsautomotive.com.au/ca ... vicing.htm Click handbook servicing then morris in the yellow box then mini then year model then engine size then up comes up what to do between 10000km to 300000km in 10000km intervals There is a leyland there but nothing comes up under mini |
Author: | Mick [ Fri Aug 01, 2014 10:37 am ] |
Post subject: | Re: mini service km list |
Took a little navigation to get to the result, but I like how it even reccomends the windscreen wiper refills. Its like an old workshop service database. If only it also told you to check the grease points and adjustments. |
Author: | drjbeam [ Fri Aug 01, 2014 1:01 pm ] |
Theres a grease can at 1 2 and 3 hundred thousand i take that as grease points But i wouldnt leave it that long between greasing And the task list is hard to read arr well |
Author: | Mick [ Fri Aug 01, 2014 4:19 pm ] |
300 thousand! No wonder they need some serious remediation work by the time the board members here get their hands on them.... |
Author: | Morris 1100 [ Fri Aug 01, 2014 5:07 pm ] |
So I need to change the diff oil at 100,000? |
Author: | Mick [ Fri Aug 01, 2014 5:09 pm ] |
Yeah, that's about the right time ![]() |
Author: | womble99 [ Fri Aug 01, 2014 5:11 pm ] |
I think you can take the site with a grain of salt, I had a look at my Magna for the 105k service which includes the timing belt replacement. Yet it doesn't mention you need to replace the mongrel platinum plugs while you half the engine pulled apart at the same time ![]() |
