Nuts and Bolts https://www.ausmini.com/forums/viewtopic.php?f=2&t=86747 |
Author: | Morri68 [ Mon Aug 04, 2014 10:05 am ] |
Post subject: | Nuts and Bolts |
Hi all where does everyone get all there nuts, bolts, screws, clips etc for when you are doing a full nut and bolt restoration on a morris mini deluxe. Cheers Hayden |
Author: | Chux [ Mon Aug 04, 2014 11:57 am ] |
Post subject: | Re: Nuts and Bolts |
viewtopic.php?f=2&t=84294 it's a heavy kit, the freight is the nasty bit. |
Author: | Mick [ Mon Aug 04, 2014 11:59 am ] |
This is another one, its in the How-To. viewtopic.php?f=25&t=84418 You can take your bolts as you collect them, including washers, spring washers, plates and fabrications etc off to a Zinc Plater to have them replated. Throw everything in is my advice, exclude the hi-tensile head bolts, they won't retain their tensile strength, but everything else will come up great. A 20 litre bucket cost 80 dollars last time. That's maybe 20 or 30 kilograms of stuff. They look a million dollars, and its cheaper in all by half maybe. |
Author: | davem [ Mon Aug 04, 2014 12:33 pm ] |
Mick for a noob like myself how do you tell the difference between hi tensile and a normal bolt? |
Author: | Mick [ Mon Aug 04, 2014 1:07 pm ] |
Bolts are marked with strikes on the bolt head, Like in this link. They're usually black in finish, like a head bolt or wheel stud for example. http://www.hi-tensilebolt.com.au/Head%20Markings.html The ones to not include off the top of my head would be the head bolts/studs, as well as the big end bolts/studs, main bearing bolts/studs, and their respective nuts. Also the steering column pinch bolt, brake caliper bolts, steering arm bolts, wheel studs, in fact any part on the brakes except the backing plates or dust covers which come up great. Everything else on the car can be thrown through the process. Then I sort them into tubs at the back end ready for use. Years later I am still running off the profits of an 80 dollar investment in plating a bucket full of bits. Springs need to be put in an oven at hi temp (max on a home oven) for a couple of hours to be normalised, but the plater will usually do this for you. ![]() |
Author: | ykg2s4 [ Tue Aug 05, 2014 7:22 am ] |
Hi Mick, where did you get your plating done? |
Author: | Mick [ Tue Aug 05, 2014 8:17 am ] |
You will need to go to Melbourne or Sydney most likely and you need to ask for a barrel plating process for the bucket of nuts and bolts. I was living in Melbourne until 3 years ago, so had them done at Alliance Electroplating at Campbellfield. There are plenty about, look up electroplating on Google Maps and start calling around. |
Author: | Minimadmarty [ Tue Aug 05, 2014 9:37 am ] |
Babes a Perth member on Ausmini sells the 'Mini in a Box' |
Author: | wild_willy [ Tue Aug 05, 2014 10:13 am ] |
Mini Fasteners for 850/Cooper Rear Subframe 2of 5/16 UNF x 2 1/2 High Tensile Set Screw Zinc Plated (front trunion long) 2of 5/16 UNF x 1.1/4 High Tensile Set Screw Zinc Plated (HTSSF516114Z) (front trunion short) 2of 5/16 x 2 1/2 UNF High Tensile Bolt Only Zinc Plated (HTBOF516212Z) (rear trunion long) 2of 5/16 x 1 1/4 UNF High Tensile Bolt Only Zinc Plated (HTBOF516114Z) (rear trunion short) 8of 5/16 UNF x 3/4 High Tensile Set Screw Zinc Plated (HTSSF51634Z) (trailing arm support bracket to subframe) 4of 5/16 x 1 x 12G Engineers Flat Round Washers Zinc Plated Need to source 4of 5/16 UNF Nyloc Nuts Zinc Plated (NNF516) 2 of 5/16UNF x 3 ¾ High Tensile Set Screw Zinc Plated (handbrake quadrant) HTBOF516334Z Note: All bolts SAE Grade 5 Front subframe/ Steering 6of 5/16 UNF x 3/4 High Tensile Set Screw Zinc Plated (HTSSF51634Z) 4of 5/16 x 7/8 x 18G Engineers Flat Round Washers Zinc Plated 6of 5/16 UNF Nyloc Nuts Zinc Plated (NNF516) Note: All bolts SAE Grade 5 1 of ¼ UNF x1 3/8” Grade8 (steering column pinch bolt) 11/2 “ available needs to be cut down Interior Door rubber scuff plate 8of 6G x 1/2 Pan Head Phillips Self Tapping Screws Zinc Plated (PPSTS6G12Z) $2.42/100 Rear quaterlight windows 14of 6G x 1/2 Grade 304 Stainless Steel Countersunk Head Phillips Self Tapping Screws (SSCPSTS3046G12) $6.16/100 Heater to dash panel 2of 10G x 1/2 Pan Head Phillips Self Tapping Screws Zinc Plated (PPSTS10G12Z) Companion box trim fixing Heater vent fixing 4of 8-32 UNC x 1/2 Raised Countersunk Phillips Metal Threads Chrome Plated Doors and catches (sliding window type) Bailey channel to door channel 6of 6G x 3/8 Grade 304 Stainless Steel Countersunk Head Phillips Self Tapping Screws (SSCPSTS3046G38) $5.94/100 Door pocket trim fixing 6of 6G x 1/2 Pan Head Phillips Self Tapping Screws Zinc Plated (PPSTS6G12Z) $2.42/100 Pocket moulding Clip 13H524 Striker plate 6of 8-32 UNC x 3/4 Raised Countersunk Phillips Metal Threads Zinc Plated (CPMTC8G34Z) Note: trim to 0.6” and should be Raised CS for originality Need to source Buffer to door 4of 6-32 UNC x 3/4 Countersunk Phillips Metal Threads Zinc Plated (CPMTC6G34Z) Buffer retainer to door pillar 4of 6-32 UNC x 1/4 Countersunk Phillips Metal Threads Zinc Plated (CPMTC6G14Z) Retaining straps 8of ¼ UNF x 0.85 Raised Countersunk Phillips Metal Threads Chrome Plated Locks 6of 8-32 UNC x 1” Raised Countersunk Phillips Metal Threads Zinc Plated Need to source 2of 8-32 UNC Gr.5 Hex Nut Zinc Plated (HNC8GZ) AU$42.46 (per 100) 6of 5mm External Lock Washers Zinc Plated (ESWM5Z) AU$1.85 (per 100) Upper finisher clip (Cooper only) 13H525 Instruments and Electrical Speedo cowl to dash panel 4of 8-32 UNC x 1/2 Pan head Phillips Metal Threads Zinc Plated Need to source Switch panel mounting 2of 8-32 UNC x 1/2 Pan head Phillips Metal Threads Chrome Plated Need to source Front parking lamp 6of 6G x 1/2 Pan Head Phillips Self Tapping Screws Zinc Plated (PPSTS6G12Z) $2.42/100 Headlamp mounting 8of 8G x 1/2 Pan Head Phillips Self Tapping Screws Zinc Plated (PPSTS8G12Z) 43.52/100 Regulator mounting 2of 10G x 1.1/2 Pan Head Phillips Self Tapping Screws Zinc Plated (PPSTS10G112Z) Fuse box mounting 1of 10G x 1/2 Pan Head Phillips Self Tapping Screws Zinc Plated (PPSTS10G12Z) Dip switch 2of 10G x 1 Pan Head Phillips Self Tapping Screws Zinc Plated (PPSTS10G1Z) Loom main earth 1of ¼ UNF x3/8 Pan head Phillips Metal Threads Zinc Plated Need to source |
Author: | BKozan [ Tue Aug 05, 2014 10:23 am ] |
Avin Plating in Melbourne quoted me about $50 for 8-10kg of nuts and bolts. He made it very clear that they cannot have any paint on them, but general grease and road grime should be ok. |
Author: | Mick [ Tue Aug 05, 2014 10:52 am ] |
Thanks willy, I might steal the list to add to the How-To if that's ok. Yeah, they get narky and may reject the bucket if its all too dirty. I can understand why, it ruins their cleaning baths unnecessarily. I soak my bucket in a few litres of petrol to remove the worst of the oil and grease before handing them over. |
Author: | wild_willy [ Tue Aug 05, 2014 2:51 pm ] |
Mick, Happy to have it added if it helps out. All of these fasteners can easily be sourced locally. |
