instrument cluster
https://www.ausmini.com/forums/viewtopic.php?f=2&t=86781
Page 1 of 2
Author:  buddha clubman76 [ Thu Aug 07, 2014 6:28 pm ]
Post subject:  instrument cluster
hi I recently acquired a mini dash cluster but unsure what model or year its from, i am wondering if it would fit into a Leyland 76 clubman, any thoughts anyone can help please. im not sure how to add photos thou.
On the cluster it has a sticker with these numbers ,S0094, ar0022002, yac106930xx
Author:  Minimadmarty [ Thu Aug 07, 2014 6:32 pm ]
Post subject:  Re: instrument cluster
With the correct bracket anything will fit!
Is it a two or three gauge cluster? What do you currently have fitted?
Adding photos:
http://www.ausmini.com/forums/viewtopic.php?f=25&t=10405
Author:  buddha clubman76 [ Thu Aug 07, 2014 6:40 pm ]
currently have three gauge in there with a two wire tacho, the new one a three gauge with one wire tacho
Author:  Minimadmarty [ Thu Aug 07, 2014 6:48 pm ]
It should fit easy enough the real question is the re-wiring from dual to single wire. I'll have to handball that to one of the smarter members on here! Brains trust?...
Author:  buddha clubman76 [ Thu Aug 07, 2014 7:07 pm ]
http://s1379.photobucket.com/user/buddh ... ml?filters[user]=141072034&filters[recent]=1&sort=1&o=4
Author:  Minimadmarty [ Thu Aug 07, 2014 7:12 pm ]
http://s1379.photobucket.com/user/buddha721/media/IMG_7710_zpsde73d874.jpg.html?filters[user]=141072034&filters[recent]=1&sort=1&o=4
Hit the 'Img' icon above when in the 'Full Editor' mode then paste the photobucket link in the middle of the [img][img] that will appear :D
Author:  buddha clubman76 [ Thu Aug 07, 2014 7:15 pm ]
Author:  Minimadmarty [ Thu Aug 07, 2014 7:18 pm ]
Woohoo..... :D
Author:  buddha clubman76 [ Thu Aug 07, 2014 7:20 pm ]
Author:  buddha clubman76 [ Thu Aug 07, 2014 9:47 pm ]
anyone else have any idea of whether we have its just a cable change for the speedo or do we hav to change the gears also
Author:  MiniVLT [ Fri Aug 08, 2014 7:19 am ]
To find out if you need different speedo drive gears you first need to know the Turns Per Kilometer or Turns Per Mile of your old and new speedo.
Check out this site, http://www.guess-works.com/Tech/speedo.htm the second pic down shows where the TPK / TPM will be.
Cheers Shane
Author:  drmini in aust [ Fri Aug 08, 2014 7:45 am ]
All Oz Minis had the same speedo drive gears in the gearbox.
Unlike most non-British cars, the speedo head was changed if the diff ratio was.
Author:  John Smidt [ Fri Aug 08, 2014 1:25 pm ]
Speedo is out of a Mini sold in japan and would be made by Nippon Seiko and fitted to a 1275 mini with 12 inch wheels I am not sure what final drive, check the revs per Klm or revs per ml on the face of the speedo
Author:  drjbeam [ Fri Aug 08, 2014 9:26 pm ]
Thought it was from japan
Author:  buddha clubman76 [ Sun Aug 10, 2014 12:07 pm ]
ok there is no number on the face of the speedo, but there is a number on the shaft inside of 780, as shown in the guessworks link does this sound about right?
