i think the car is sick....blown head gasket? https://www.ausmini.com/forums/viewtopic.php?f=2&t=8690 |
Author: | I_AM_THE_WAHL [ Sat Jul 02, 2005 1:22 pm ] |
Post subject: | i think the car is sick....blown head gasket? |
hey people thought i would be nice to the car to day and flush the cooling system seeing the heater stoped working again anyway now after i refilled the system i get a rather slow bubbling comming from the radiator and when you put the cap back on the revs die down. the head was off a three weeks ago could it be that it need ed a retorque sooner or do you think i have bigger problems help..... |
Author: | drmini in aust [ Sat Jul 02, 2005 8:12 pm ] |
Probably too late now, but you should always retighten them, regardless of the `Monotorque' blurb on some of the packaging. Sometimes they go down more, sometimes not- but I never take the risk of leaving it. I tighten them, run until hot, tighten again. If it's my car I check again at 1,000 miles or so. And for iron heads (Mini, early Holden etc) they should be redone HOT! So I was taught 40 years ago, anyhow. ![]() BTW alloy heads are retightened when COLD..... |
Author: | I_AM_THE_WAHL [ Sat Jul 02, 2005 8:20 pm ] |
thank you i figured that might be the case, ive decided that i will take the motor out and give it a total refresh any way seeing the amount of smoke it blows most mornings any way at least the heater works again ![]() |
Author: | gafmo [ Sat Jul 02, 2005 10:59 pm ] |
What gasket were you using on a 998/1098 ![]() |
