It is currently Mon Aug 04, 2025 9:59 pm
 Post subject: 22G846 gearbox
PostPosted: Sat Aug 16, 2014 4:01 pm
I have dug out my 22G846 gearbox case and I'll need to build it up to support and handle the power from my 1360 BMW twincam engine. I hope the engine will make over 100bhp and I plan to tune it for torque, I will be running a 3.1 or 3.2 FD and a Quafie ATB (LSD). It will be a daily driver so no SC gears but I do like longer gears, (I don't want to be in 3rd at 40km doing 3000rpm :roll: )
From memory when I disassembled it I found broken teeth on the laygear. How do I find out what gear ratios the originals are :?:
Should I upgrade to a different, stronger gear set cluster/is there a difference :?:
What are peoples suggestions?
 Post subject: Re: 22G846 gearbox
PostPosted: Sat Aug 16, 2014 4:32 pm
Thats an elf box? Do they take the standard 22G927 4 syncro laygear?
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Sat Aug 16, 2014 6:36 pm
The Mini King
Yes they will
with a little bit of fiddling around you can use the gears that are commonly called A plus gears if so desired I am talking about the internal gears not the drop gears, however even that can be achieved with a fair bit of work.
I am sure Dr Kev will be able to advise you further
PostPosted: Sat Aug 16, 2014 7:15 pm
I have the same box under my 1360. Treat it as a 1128 box. Same same.
PostPosted: Sun Aug 17, 2014 7:05 pm
Can you fit a 4 syncro rod change gear set into this case?
PostPosted: Sun Aug 17, 2014 8:02 pm
If its like a 22G1128 then yes. Only the reverse gear is different.
5/72 Clubman Gt
Users browsing this forum: winabbey and 98 guests
