It is currently Fri Jul 18, 2025 9:22 am
 Post subject: overall width
PostPosted: Sat Feb 21, 2015 7:10 pm
Can anyone tell me the width of a mini, including standard flares. I would assume round nose and clubmans are the same. I've been searching the net and can't find it, only standard mini's. Or maybe someone on central coast that I can measure.
 Post subject: Re: overall width
PostPosted: Sat Feb 21, 2015 9:34 pm
so you want the exact overall width of the widest part of a MK2 Cooper S or Leyland Mini S (or LS, SS, 1275 LS etc.) with standard wheels fitted and standard front wheel camber?
I could measure my MK2, I have standard wheels but I have 1.5* lower arms so the bottom of my wheels poke out a bit further than standard... I also have a008 tyres which are pretty wide compared to what were the standard tyres
Minis are usually widest at the bulge at the bottom of the front tyres, kinda like a cats whiskers I guess - if the tyres fit, then the rest of the car will fit
PostPosted: Sat Feb 21, 2015 10:31 pm
My car's in Qld and I'm trying to built a trailer and get ramps etc in right place. My tyres stick out so the flares just cover tread, so I'm guessing an 1" wider than Std cooper s should be the right width.
PostPosted: Sun Feb 22, 2015 6:32 pm
I'm sure there used to be a sticky some where that had the mini dimensions... Trying to find it
Life's a garden.... Dig It!
PostPosted: Sun Feb 22, 2015 6:44 pm
Hope these are of assistance
PostPosted: Sun Feb 22, 2015 6:51 pm
Peter , i just put a rough chalk mark on the floor , about 1" outside the front wheels on my car ( 6"rims + flares ) and measured it at 1550mm .
PostPosted: Mon Feb 23, 2015 7:47 am
Thanks Goodie, I'll go with that measurement. I didn't want to make trailer too narrow, for obvious reasons, but not too wide that it takes up too much room. I'm going to make ramps width such that it'll fit an orange box when I get one, right up to the widest 'legal' width. (1600mm?)
