how long does it take you to ..
https://www.ausmini.com/forums/viewtopic.php?f=2&t=86949
Author:  deluxe67 [ Wed Aug 20, 2014 9:37 pm ]
Post subject:  how long does it take you to ..
change a fan belt?! I have a quick release grill so thought no probs. well after having to remove top radiator shroud, dealing with a thermo housing stud and general rooting around, it took me an hour and a half! In a workshop, not on the side of the road. The replacement belt had a beefier profile which meant I needed a tyre lever to squeeze the bugger past the harmonic balancer but still, hour and a half. Is this normal?!
Author:  Minimadmarty [ Wed Aug 20, 2014 9:46 pm ]
Post subject:  Re: how long does it take you to ..
Yeap
Author:  simsy98 [ Wed Aug 20, 2014 11:01 pm ]
Its easier to take the motor out :p
Author:  Morris 1100 [ Thu Aug 21, 2014 5:56 am ]
Takes me about ten minutes.
Author:  TheMiniMan [ Thu Aug 21, 2014 7:20 am ]
^^^^^^ me too :-)
Author:  drmini in aust [ Thu Aug 21, 2014 7:29 am ]
No need to remove the top rad shroud, it has a clearance gap at the top/front to get the belt over the fan blades.
10 mins belt change is about right, unless the engine mount bracket has sagged too close to the harmonic balancer. Then you need to loosen the 2 horizontal bolts and stick a jack under the gearbox to give room.
