Clunk noise https://www.ausmini.com/forums/viewtopic.php?f=2&t=87224 |
Author: | kath20 [ Thu Sep 18, 2014 2:01 pm ] |
Post subject: | Clunk noise |
When driving my MK11 Cooper S home before I started the strip down I noticed a clunk noise when on off the accelerator,as I am pulling the car down I thought that Somebody might be able to give me a heads up as to what the problem might be.I grabbed the top of the engine but can't rock it back & forward even though the stabiliser rubbers look worn. cheers. |
Author: | timmy201 [ Thu Sep 18, 2014 2:29 pm ] |
Post subject: | Re: Clunk noise |
It could be the rubber mount where the remote change housing bolts to the body underneath? Mine had a similar clunk before I changed it.. |
Author: | gtogreen1969 [ Thu Sep 18, 2014 2:39 pm ] |
It is easier to test the engine movement by putting it into gear, handbrake off and rocking the car back and forth. |
Author: | drmini in aust [ Thu Sep 18, 2014 2:44 pm ] |
Check the big CV nut on each hub, if loose that gives a good clunk. Usually it means the drive flange and/or CV's spline is worn. |
