It is currently Sat Jul 19, 2025 10:40 pm
 Post subject: Panelvan vents
PostPosted: Thu Sep 18, 2014 7:17 pm
Did all Mini panelvans come with roof vents?
If not, when did they start?
Would this have been patched - given it is a ribbed roof?
And the authenticity of it being Austin?
(round, chrome door safety bosses?)
 Post subject: Re: Panelvan vents
PostPosted: Thu Sep 18, 2014 7:38 pm
Not sure willy. I have been looking at vans but there isn't a huge amount of info out there. I have seen a 71 Austin without a vent if that helps?
CJ
edit - it is hard to spot as it is an old link but towards the bottom of the page the blue van has no vent http://www.minicityltd.com/pgCarsforsale/carsforsale.html
edit - going back though my PM's according to Watto all Vans started with vents http://bmcexperience.com.au/issue-21/mini-van.html I don't know when they stopped making them with vents? Aussie ones had vents right through to the K according to the adverts. Clubbies I am not sure?
PostPosted: Thu Sep 18, 2014 8:38 pm
my vans 65 yes 69 yes 73 no 78 no ??
65 panel van Sprog
73 panel van Iggy
PostPosted: Thu Sep 18, 2014 9:50 pm
My 77 has a vent!
Guessing its original... :?
1977 Leyland Mini Van - Sold
PostPosted: Thu Sep 18, 2014 9:52 pm
I thought it was a dealer or after market option.
PostPosted: Fri Sep 19, 2014 8:09 am
No vent on my '73.
PostPosted: Fri Sep 19, 2014 8:24 am
That's a pommy van, right?
PostPosted: Fri Sep 19, 2014 6:06 pm
Just to throw you a bit look at my van in my avatar :D .
It's a 74 and has no roof vent, I also have a 76 and a 78 with no vents.
PostPosted: Fri Sep 19, 2014 8:11 pm
The last of the Australian round-nose Mini parts books (PUB1056M) shows the vent as standard, not an option. In case it means something to Van people, the part number for the roof changed at car number YJBAV2R-794, whenever that was, and the vent continued. The early Clubman van had the same roof. Later Clubman van parts are on microfiche but I'm not home so can't check when the vent was deleted.
Edit: In the Clubman van brochure here there is no vent - viewtopic.php?f=32&t=73880
PostPosted: Fri Sep 19, 2014 8:48 pm
That van has Japanese rego, so its probably British and could be as late as 1982. It shouldn't have that grille but could be an Austin.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Fri Sep 19, 2014 9:59 pm
If you look carefully it has extra holes on the scuttle for wipers for when the go to left hand drive I think that is a 70's-80's thing
