Manifold with a difference https://www.ausmini.com/forums/viewtopic.php?f=2&t=87227 |
Author: | TheMiniMan [ Thu Sep 18, 2014 6:32 pm ] |
Post subject: | Re: Manifold with a difference |
Noice ![]() we ran a down draft weber years ago & it worked a treat but i don`t know where it went i suspect it was stolen, or dad may have sold it while i wasn`t looking ![]() |
Author: | smac [ Thu Sep 18, 2014 6:39 pm ] |
When I first got my hands on my 1380 (in an Elf!) it ran a down draft off a cortina ( I think?)? Everybody told me how crap they were. Nobody could believe how the car went so well.... (yet they still told me the carb was crap....). Huh. |
Author: | slide [ Thu Sep 18, 2014 6:54 pm ] |
I was toying with the idea of trying a 32/36DGV downdraught Weber on my van. The carbs and manifold are available new from Minimania, Carbs Unlimited, Redline in the US complete with jetting kits. But again everyone says don't bother, they're crap (including Ketih Calver!).... |
Author: | drmini in aust [ Thu Sep 18, 2014 6:55 pm ] |
smac wrote: When I first got my hands on my 1380 (in an Elf!) it ran a down draft off a cortina ( I think?)? Everybody told me how crap they were. Nobody could believe how the car went so well.... (yet they still told me the carb was crap....). Huh. Yeah I had a similar 2 barrel downdraft to that, standard on my Fiat 124AC Sport. But an IDF Weber is a totally different design to the old 2 barrel Webers used on Cortinas, Escorts, Fiats etc. This IDF works much the same as a sidedraft DCOE does. Each barrel feeds one head port. Much better for HP. |
Author: | GR [ Thu Sep 18, 2014 7:19 pm ] |
HI All These carbies are like the 48IDA down draft weber that David Visard tells about in his book only they are smaller, the one i used is a 44mm IDF as used on Ferrari's they are much smaller in height than the IDA's so they don't have to go through the bonnet they also come in smaller sizes 40mm 42mm and the 44mm. Graham Russell |
Author: | Hobson [ Thu Sep 18, 2014 10:27 pm ] |
Could it be, :O part 4 or a side note on project small bore? LE GASP |
Author: | GR [ Fri Sep 19, 2014 7:09 am ] |
HI Hobson Yes there is another small bore project it's about a 68mm motor how to do it as in boreing it and what to block off in the head and block, i will be trying different things like with the head i have fitted bigger inlet valves with no porting at all, i will dyno the motor take the head off modify the exhaust ports and see what the difference is HP wise and then do the inlet ports and see what the difference is, i will then try difference types of carbie set up's, as you can see in the photo's the motor is built just need a little time and help. Graham Russell |
Author: | poeee [ Fri Sep 19, 2014 8:14 am ] |
Is the manifold fabricated steel, GR? |
Author: | Mick [ Fri Sep 19, 2014 8:18 am ] |
Downdraft on the 850 Scott? ![]() |
Author: | poeee [ Fri Sep 19, 2014 8:21 am ] |
She wants the 998 auto in it. |
Author: | TK [ Fri Sep 19, 2014 8:40 am ] |
So how big is the filter that will clear the bonnet? Do you have any pics of it in a mini? |
Author: | 1071 S [ Fri Sep 19, 2014 6:22 pm ] |
IDA fits under the bonnet ...just not the ram tubes/filter...... IDFs were also used by Porsche (if you happen to have an old one lying around the back yard:). Probably more likely to find an old VW hotup kit. Cheers, Ian |
Author: | drmini in aust [ Fri Sep 19, 2014 6:56 pm ] |
Twin 40IDFs or Dellorto equivalent were used on 1971> Fiat 124BC Sport, people used to bung both these carbs on Geminis back in the day. Lynx made a manifold for them. [edit] typo |
Author: | GR [ Fri Sep 19, 2014 6:58 pm ] |
HI Poeee Yes it is made out of steel. Hi TK On my LS1275 it has 1.5 ins clearance, on the net you can get filters for the IDF down to 25mm on the small bores it has more clearance,they use these carbs a lot in the USA on VW in off road vehicles,they are a very good little carb. Graham Russell |
