It is currently Sat Jul 26, 2025 4:53 pm
PostPosted: Thu Oct 02, 2014 8:47 pm
Hi, could I get some info on this round nose panelvan from the build plate?
PostPosted: Thu Oct 02, 2014 8:59 pm
You have cut the top off but from the engine number it could possibly be a K Van? This site http://www.mini.org.au/mini_identification.html lists that engine prefix as belonging to a 1100 Mini K Van.
PostPosted: Thu Oct 02, 2014 9:05 pm
I'll get another pic
PostPosted: Thu Oct 02, 2014 9:07 pm
Mini K would be a good start being round nose and 1098. Brains trust could probably help more with the numbers side of things.
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Thu Oct 02, 2014 9:37 pm
Is it normal for the id plates for that era to be this scratched and messed up? Would there be any issues getting it registered?
PostPosted: Thu Oct 02, 2014 10:11 pm
Get a stiff bristled toothbrush & some WD40 and give the plate a bit of a scrub , see how it comes up .
PostPosted: Fri Oct 03, 2014 5:43 am
I think it is a 1969 Mini K van (Morris Mini 1100 Van).
The ID plate will probably say..
Model = Mini Van
Type = YJBAV4R
Serial Number = ? (somewhere around the 3800 mark I would guess)
Engine Number = 10YJUH 4233
Colour = 1/Cadet Blue/1
GVW = 2044lbs
There is no problem with a scratched ID plate. There is no legal requirement for them except commercial vehicles must have a GVW weight which is why vans had ID plates in 69 when the sedans didn't.
PostPosted: Fri Oct 03, 2014 9:15 am
Unfortunatly this happens often when there is a brake fluid spill, a few wipes and the paint is gone from the plate, the lower section of my ID plate is like this.
As stated not a requirement for rego, but they should/will be more interested in the stampings in the actual body (which should match the number on the plate)
PostPosted: Mon Oct 06, 2014 8:02 pm
Here's a better picture.
