Help identifying this panelvan
https://www.ausmini.com/forums/viewtopic.php?f=2&t=87369
Author:  waznotme [ Thu Oct 02, 2014 8:47 pm ]
Post subject:  Help identifying this panelvan
Hi, could I get some info on this round nose panelvan from the build plate?
Author:  womble99 [ Thu Oct 02, 2014 8:59 pm ]
Post subject:  Re: Help identifying this panelvan
You have cut the top off but from the engine number it could possibly be a K Van? This site http://www.mini.org.au/mini_identification.html lists that engine prefix as belonging to a 1100 Mini K Van.
Author:  waznotme [ Thu Oct 02, 2014 9:05 pm ]
I'll get another pic
Author:  Scoop [ Thu Oct 02, 2014 9:07 pm ]
Mini K would be a good start being round nose and 1098. Brains trust could probably help more with the numbers side of things.
Author:  waznotme [ Thu Oct 02, 2014 9:37 pm ]
Is it normal for the id plates for that era to be this scratched and messed up? Would there be any issues getting it registered?
Author:  goodie [ Thu Oct 02, 2014 10:11 pm ]
Get a stiff bristled toothbrush & some WD40 and give the plate a bit of a scrub , see how it comes up .
Author:  Morris 1100 [ Fri Oct 03, 2014 5:43 am ]
I think it is a 1969 Mini K van (Morris Mini 1100 Van).
The ID plate will probably say..
Model = Mini Van
Type = YJBAV4R
Serial Number = ? (somewhere around the 3800 mark I would guess)
Engine Number = 10YJUH 4233
Colour = 1/Cadet Blue/1
GVW = 2044lbs
There is no problem with a scratched ID plate. There is no legal requirement for them except commercial vehicles must have a GVW weight which is why vans had ID plates in 69 when the sedans didn't.
Author:  phillb [ Fri Oct 03, 2014 9:15 am ]
Unfortunatly this happens often when there is a brake fluid spill, a few wipes and the paint is gone from the plate, the lower section of my ID plate is like this.
As stated not a requirement for rego, but they should/will be more interested in the stampings in the actual body (which should match the number on the plate)
Author:  waznotme [ Mon Oct 06, 2014 8:02 pm ]
Here's a better picture.
