It is currently Wed Jul 23, 2025 11:06 pm
 Post subject: fuel economy
PostPosted: Thu Oct 02, 2014 9:59 pm
I am working out my economy and am at this,
250 km per 20 to 21 litres.
driving in easy mode.
how are you all going?
It's easy once you know how.
 Post subject: Re: fuel economy
PostPosted: Thu Oct 02, 2014 10:05 pm
7.5 litres / 100km average I guess from a 1275.
PostPosted: Thu Oct 02, 2014 10:09 pm
i drive to work daily in the mini... about 30 - 35km round trip with 1 foot to the floor steep hill on the way.
And might do 1 or 2 other trips or deviations to my norm each week
I dont specifically keep track of it but i fill up every 5 or 6 working days so travel about 200 - 250km between fill ups and put maybe 16-20 liters in each time
So my numbers would match yours pretty well.
Mine is a bog standard 998 by the way.
1975 Hairy Lime/White Clubby
PostPosted: Thu Oct 02, 2014 11:34 pm
There is an app you can put on your Android or other type to track economy.
I take a photo of my k's and the receipt and from time to time stick it in a spreadsheet.
I haven't done it recently so it would be interesting to see how things have changed since the carby was done and also since we took the stupid rich needle out...
Alec
PostPosted: Fri Oct 03, 2014 10:21 am
I drove mine to work for a week (70km return) and got 7.2L/100km average. I only have the single small tank, so I filled up a couple of times that week!
It's a standard deluxe 998, at least 50% of the trip is in a 100kph zone too, the rest is 50/60/70
PostPosted: Fri Oct 03, 2014 10:40 am
I'm getting about 8.4l/100km. 1275 with a 45 dellorto.
PostPosted: Fri Oct 03, 2014 1:15 pm
I've been getting shy of 9l/100km out of my 998 over the last few weeks. But it needs a good tune and a wheel alignment - hopefully that will improve things.
PostPosted: Fri Oct 03, 2014 9:27 pm
Last time I did mine over a month I got 6.9L/100
PostPosted: Sat Oct 04, 2014 6:47 am
My Hairy lime mini which has a 1380cc with HIF44 . 104 cam and very slightly worked head, extarctors electronic ignition, and fitted with 3.1 diff ratio does 15.6 Km to the litre. Which is 6.4 ltr to 100 KM. I love this car.
"Let us remove your "SHORTS"
PostPosted: Sat Oct 04, 2014 8:30 am
My little ratvan with a 60thou bored 1100 and ported head running a hif38 does about 9l to 100km.
Mind you it only has 2 throttle posistions on and off....
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Sun Oct 05, 2014 8:32 pm
My 1310A+ which I've just converted back from EFI to HIF44, is getting 6.3l/100k (44.8MPG) this was over 332k's 200 using it locally and some highway and the rest with my son driving on his L plates. Very happy, as my Renault Clio only gets 6.6l/100k over the same routes.
The engine has Metro standard cam 1.5 rockers, LCB, MG Metro Turbo head and still running the MegaSquirt ECU, but only ignition.
Jim
PostPosted: Sun Oct 05, 2014 8:49 pm
I'm a nerd who likes number crunching (its my job), so I track all our cars whenever I fill them.
Our 87 Rover mini 998cc averages 8.3lt/100 (spirited peak hour melbourne driving lately)
Our 88 Rover mini 1275 spi averages 9l/100 (always ran rich so I've just accepted that and try to remain happy that it actually runs)
Our 63 Morris 850 (stock standard 850) averages 7.5l/100 which is only weekend cruising.
All are heavier on the juice that my suzuki swift which averages 6.9l/100.
88 Rover 1.3i "Reggie"
99 Rover 1.3i “Grover”
17 Mini Clubman JCW “Noddy”
PostPosted: Sun Oct 05, 2014 9:09 pm
Out of curiousity what does the original British 40mpg equal in L/100km?
PostPosted: Sun Oct 05, 2014 9:50 pm
Its about 7.1 litres per 100 klm
1 x mpg = .354005 klm per litre and then you have to convert to litres used per 100 klm
Ian
PostPosted: Mon Oct 06, 2014 7:04 pm
Think I'm getting about 13l per 100 km from my Supercharged mini. My cooper S gets about 28mpg. 1310, RE? Cam, twin 1 1/2 SUs
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
