i know this topic has been covered heaps https://www.ausmini.com/forums/viewtopic.php?f=2&t=8741 |
Author: | DarkenMini [ Sun Jul 03, 2005 6:49 pm ] |
Post subject: | i know this topic has been covered heaps |
ive done a search but i didnt realy find out what i kinda wanted to know. with the long centre branch extractors what r the power gains over 3-1 extractors is there any or its not noticeable. im pretty sure that with certain zahust setups the extractors give high end power or low end power if so what r the lcb's good for and what r the 3-1 good for? Regards. DARKEN. |
Author: | benjamin [ Sun Jul 03, 2005 8:02 pm ] |
lcb's give you more top end power than the 3to1's but the 3to1's give a nice low end torque so its up to you what you want im pretty sure thats right |
Author: | fuzzy-hair-man [ Mon Jul 04, 2005 10:44 am ] |
From what I read in Vizard there is not that much between them. But as benjamin said the LCBs have a bit on the 3-1s up top but they give a little away at lower revs. The preference seems to be for LCBs though. I have been wondering if everyone with LCBs knows something I don't ![]() ![]() Best exhaust mod is putting on an RC40 IMO after that then do the extractors but by most accounts the silencer will make the bigger difference. ![]() |
Author: | FatMaserati [ Mon Jul 04, 2005 10:56 am ] |
It all depends on what size engine you have too. If you have a big bore/stroker engine (like me), then you'd want a set of LCBs with a bigger bore width. I'm using crappy ol' 3-1s at the moment, and whilst it runs beautifully, it doesn't quite have the power it should, especially when you put your foot down. Plus, my cam's power range is from 3500-8250 revs, and my car loves it around 3500-4000. Since it loves these higher revs, it would love a bit more from the extractors. If I was you, I'd probably ditch the 3-1s and get a set of LCBs with a small bore width, which is basically the best of both worlds if you have an 1100 or something. Oh, and when I refer to 3-1s, I mean the ones that join together high up, found on older Minis, and NOT the hardcore racer 3-1s which join up underneath the chassis and are wide enough to stick your fist into. ![]() |
Author: | kazjim [ Mon Jul 04, 2005 10:56 am ] |
LCB's Sound better. ![]() J |
