Gearbox rebuild (new Q page 3) https://www.ausmini.com/forums/viewtopic.php?f=2&t=87446 |
Page 1 of 3 |
Author: | Irish Yobbo [ Sat Oct 11, 2014 6:43 pm ] |
Post subject: | Re: Gearbox rebuild |
Kennomini wrote: (1) The drain has striped out so what are my options ![]() You can get plugs for stripped drain threads here, but you will probably be better off with a helicoil. I have never used a helicoil, but i have one on my gearbox in the same place, and it works well. Kennomini wrote: (2) How do I and is it nessary to remove the speedo drive ![]() It should slide out from the side once you have removed the cover plate. You shouldn't need to touch it though. Kennomini wrote: (3) Should I replace the driveshaft output bushes (the bearing thingy) ![]() Only if they're worn, I'd say. I've never seen them wear down before, but they may well do. Kennomini wrote: (4) The top and bottom bushes in the diff housing for the gear selector shaft, the shaft seems to move around a bit in them. How tight/loose is the shaft meant to be, should I replace these ![]() They shouldn't be tight, but they should move freely with little sideways movement. I'm not sure what you would do to fix that. Kennomini wrote: (5) cleaning up the threads on everything, what taps and dies do I need ![]() Can't say off the top of my head - I'm not good with thread sizes anyway. |
Author: | Wombat [ Sun Oct 12, 2014 12:31 pm ] |
For the drain plug I helicoiled it - have some left over if you need it. |
Author: | Mick [ Sun Oct 12, 2014 12:34 pm ] |
Irish Yobbo wrote: (5) cleaning up the threads on everything, what taps and dies do I need ![]() You can take the studs out, it makes cleaning the gasket surfaces easier. Its just time consuming. You will need 1/4 and 5/16th and a 3/8 UNC finishing taps to bottom out the threads. The studs will have UNC on one end, and UNF on the other. |
Author: | drmini in aust [ Sun Oct 12, 2014 6:10 pm ] |
The 2 side cover bushes are usually worn- press new ones in then get them set up true in a lathe and machined to size for ~.001" clearance on your drive flanges or pot joints. If you leave them worn the seals won't last long before leaking. These bushes are about .007" undersize when bought. The 2 shift shaft bushes in the diff cover wear bad and should be replaced. I screw a 9/16" UNF tap in, then use a hammer and a bit of 3/8 rod to drive them out. You could also use a 14mm tap. |
Author: | simon k [ Sun Oct 12, 2014 7:29 pm ] |
4/ you can just catch the side of them with a long drift, or use a slide bearing puller. Easy job |
Author: | Kennomini [ Sun Oct 12, 2014 8:28 pm ] |
Thanks for the answers so far. Can I use selector shafts and knuckle joint parts from a 3 sycro remote box? It's only the gear clusters that are different correct ![]() ![]() |
Author: | drmini in aust [ Mon Oct 13, 2014 6:45 am ] |
The knuckles and shift shafts they attach to are the same. The selector shafts in the bottom of the box are not. The 4 synchro case is wider inside, and machined differently. Can't fit 4 synchro setup to a 3 synchro case. Go find a Mink K/1098 Clubby box.. |
Author: | Kennomini [ Mon Oct 13, 2014 5:58 pm ] |
Thanks Doc, also (I can never remember) can the gears out of a rod change be installed in a remote box ![]() |
Author: | mini_mad_matt [ Mon Oct 13, 2014 6:14 pm ] |
4 syncro gears are 4 syncro gears, doesn't matter what shift type |
Author: | Scoop [ Mon Oct 13, 2014 7:29 pm ] |
Except reverse idle gear, thats different. NLA I believe |
Author: | drmini in aust [ Mon Oct 13, 2014 8:00 pm ] |
Scoop wrote: Except reverse idle gear, thats different. NLA I believe Might be NLA new, but PM me if ya need a good s/h one. The difference in the reverse gear is the groove position for the selector fork. |
Author: | mini-dunger [ Sun Nov 02, 2014 6:43 pm ] |
I have just rebuilt a box now it's stuck in either 1st or 2nd? I can still select 3 , 4 and R ..... What have I done ? |
Author: | Scoop [ Sun Nov 02, 2014 7:27 pm ] |
Did you line up all the bell crank levers putting the selector shaft in? |
Author: | mini-dunger [ Sun Nov 02, 2014 7:32 pm ] |
Yeah I think so. I just had to replace 1st gear so I left all the selectors in. |
Page 1 of 3 | All times are UTC + 10 hours |
