It is currently Sun Jul 20, 2025 9:43 am
PostPosted: Sat Nov 15, 2014 8:58 pm
What is the difference between the standard and Cooper S diff side plate?
I know the ID is larger on the S,
But is the OD for the seal the same or also larger?
Can you modify a standard side plate to fit the S?
(S being Hardy Splicer Joints)
Thanks in advance.
PostPosted: Sat Nov 15, 2014 9:32 pm
I thinks the o/d of the seal is slightly large. 47.3mm o/d normal and 50mm o/d for the S type.
Thats what I found looking on the web anyway.
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Sat Nov 15, 2014 9:50 pm
some later Moke side plates can be modded (bored) but I just use Morris 1500 side covers with a minor mod (skim).
PostPosted: Sat Nov 15, 2014 11:03 pm
The S seal is 1/8" bigger on OD and ID. So is the bronze bush, and it's 5 times dearer than a Mini one.
So you have to bore the cover for both. And then fit & bore the bush, as they are supplied ~.007" undersize.
The side covers to bore out are the ones with a machined ring on the outer corner, where a shroud was fitted. I think Mini K and early Clubby had these, as well as the Mokes. They have no part number on them...
These covers have more meat around the bush than the early ones.
