It is currently Sun Aug 10, 2025 3:14 pm
PostPosted: Thu Nov 27, 2014 5:58 pm
Why do various Mini shops in Oz continue to sell the switch pictured as a GAE131? It is Jag or something, not Mini.
Thanks for the pic Classic Motoring, and you are not the only ones I'm picking on.
THIS SWITCH SCREWS IN, BUT DOES NOT WORK in a Mini remote box.
The plunger is too big diameter, so it hits the spring not the actuating rod. No worky.
Twice lately I have had to source S/H original switches instead. Thanks, John Smidt.
PostPosted: Fri Nov 28, 2014 8:41 pm
Thanks Kev and John (for supplying the correct working switch)
Worked first go correct plunger pin length (my sealing washer was 0.031" thicker so I added this to the pin length)
"Boris" - '69 Cooper S Mk 2
