It is currently Sat Aug 02, 2025 5:28 pm
 Post subject: welding question
PostPosted: Tue Jul 05, 2005 3:11 pm
do i need to unplug the battery when useing a stick welder on my car?
PostPosted: Tue Jul 05, 2005 3:12 pm
I would think it'd be advisable.
Bob Slattery
PostPosted: Tue Jul 05, 2005 3:35 pm
Yeah do it as a precaution.
Even though you can hold metal while you weld it (it doesnt carry any currnet), electrical bits could be effected if you don't unplug the battery first.
PostPosted: Tue Jul 05, 2005 3:49 pm
Speaking of welding look what I just found :shock: http://www.vintageprojects.com/metal-welding/SpotWelder.pdf
David L
PostPosted: Tue Jul 05, 2005 3:56 pm
Um I think there is current there it is just all going through the earth from the welder instead of using big willy as an earth :D :P Electricity takes the shortest and easiest path to earth it'self out. Wires have less resistance than you do.
Hence you stick your bum in the air whilst kneeling if you are caught in a electrical storm (and keep your head down) idea is that the lightning hits your bum and goes and earths out at your knees instead of hitting your head and sending current through your brain and heart, hence you are more likely to survive.
Roads need more corners
 Post subject: Re: welding question
PostPosted: Tue Jul 05, 2005 4:27 pm
Yes.
If not, you run the risk of:
a) buring out your wiring loom & a possible fire
b) destroying the diodes in your alternator
c) blowing up (literally) your battery
Not worth the risk when all you have to do is remove the earth clamp IMHO.
Mike
PostPosted: Tue Jul 05, 2005 5:28 pm
all done removed the earth clamp tried welding but looks as if i need a oxy or mig as the stick wont weld thin metal anyway its tacked so all good :)
PostPosted: Tue Jul 05, 2005 10:25 pm
i would reccomend mig :| oxy is wayyyy too hard, for me anyway, i still blow holes in 1mm steel...although i am learning. but if mig is accesible, go that over oxy anyday!
I have a problem.. apparently
Users browsing this forum: Bing [Bot] and 92 guests
