It is currently Sat Aug 16, 2025 10:16 am
 Post subject: Front subframe rebuild
PostPosted: Thu Dec 11, 2014 6:43 pm
I am about to strip and rebuilding a front subframe (dry) and it looks like the mounting bolts on the towers will need replacing. Before I get to far into the rebuild is it possible to replace these bolts once the cone has been removed??
PostPosted: Thu Dec 11, 2014 7:12 pm
Hi cogs I'm fairly certain that dry subframes use studs on the towers, so they can be removed with the cones in place.
PostPosted: Thu Dec 11, 2014 7:35 pm
It will be great if thats the case will have a closer look tomorrow. I just did not want to get too far into the job only to find out that the subframe was U/S just because of rusted bolts.
Thanks for the advice
PostPosted: Sat Dec 13, 2014 8:58 pm
Cogs.
Just pulled a front frame apart last week. The top studs can be hard to get out. I,d recommend WD40 overnight. Then,at least two Vice Grips locked on HARD. Grab both gripes and try and rock it slightly back and forth. If you get it moving, more WD40. Back and forward continuously.
Cheers Alex.
PS: What state you in?
Users browsing this forum: No registered users and 243 guests
