Hub, build up sequence?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=87992
Author:  davem [ Fri Dec 12, 2014 4:31 am ]
Post subject:  Hub, build up sequence?
I finally received these yesterday but l am concerned that l may build these wrong, from left to right in the pic is this right, and what's the fat washer for in the bag?
Thanks
Author:  simo74 [ Fri Dec 12, 2014 6:40 am ]
Post subject:  Re: Hub, build up sequence?
viewtopic.php?f=25&t=77858
Check this out in the how to section it is for a drum to disc conversion but includes assembling the hubs. Might help
Author:  boomini [ Fri Dec 12, 2014 7:19 am ]
The clear plastic thing is a dust seal that goes on outside of the inner seal. The fat washer is the spacer shim that goes between the 2 bearings inside the hub.
Author:  davem [ Fri Dec 12, 2014 7:46 am ]
thanks simo74 and boomini
Author:  Hobson [ Fri Dec 12, 2014 10:19 am ]
If you are having issues, getting the bearings in, stick it on a cook-top.
Author:  Mick [ Wed Dec 31, 2014 8:44 am ]
I thought the white thing was a seal spacer to stop the rotating bearing contacting the seal! Was I mistaken ?
Author:  BKozan [ Wed Dec 31, 2014 8:52 am ]
You are mistaken, boomini is right. :)
The white plastic guy is a dust seal, off all those parts, it will be the closest thing to the diff.
Author:  drmini in aust [ Thu Jan 01, 2015 8:59 am ]
The white plastic thing is a water/slush excluder, as said it goes against the CV body, and sits in the grooved seal.
It is a UK thing, all Oz Minis just had 2 normal seals the same as the outer one shown.
