It is currently Sun Aug 17, 2025 6:15 pm
 Post subject: HELP Clutch problem
PostPosted: Sun Dec 14, 2014 9:40 am
Hi My clutch went rock hard on a drive do you think it's the slave cylinder ?
 Post subject: Re: HELP Clutch problem
PostPosted: Sun Dec 14, 2014 9:54 am
no - if it was something hydraulic leaking it'd go soft... check that the throwout stop nut (the big one poking out of the wok) hasn't screwed itself in.
PostPosted: Sun Dec 14, 2014 9:57 am
Is it actually releasing? The hose might have blocked. The pedal returns but the clutch won't return at the slave.
PostPosted: Sun Dec 14, 2014 10:21 am
I replaced the hose with a second hand one i had and starded to bleed the clutch. The arm that pushes the clutch in was moving then it went rock hard. There's no nut on the end.
PostPosted: Sun Dec 14, 2014 10:33 am
Sounds like you may have seized plunger in either master or slave cylinder, could also be thrust bearing shaft in wok.
I have seal kits for both in stock, and plenty of spares if issue is with Wok
Mal
BMC
Bowden Minisport Customs
0418469188
PostPosted: Sun Dec 14, 2014 10:40 am
Thanks guy's I'll take it apart today and let you know
PostPosted: Sun Dec 14, 2014 11:16 am
When the hose blocks up it will block on the return. You can push it down but the clutch will not release.
When you press it again the pedal will be rock hard because the clutch is already down even though the pedal is up.
Take a look at where the adjuster bolt is, is there a big gap between the adjuster bolt and the clutch arm?
PostPosted: Sun Dec 14, 2014 12:08 pm
Thanks I'll check it when I get home
Users browsing this forum: No registered users and 121 guests
