welding question https://www.ausmini.com/forums/viewtopic.php?f=2&t=8802 |
Author: | benjamin [ Tue Jul 05, 2005 3:11 pm ] |
Post subject: | welding question |
do i need to unplug the battery when useing a stick welder on my car? |
Author: | MrBob [ Tue Jul 05, 2005 3:12 pm ] |
I would think it'd be advisable. |
Author: | willy [ Tue Jul 05, 2005 3:35 pm ] |
Yeah do it as a precaution. Even though you can hold metal while you weld it (it doesnt carry any currnet), electrical bits could be effected if you don't unplug the battery first. |
Author: | Wombat [ Tue Jul 05, 2005 3:49 pm ] |
Speaking of welding look what I just found ![]() |
Author: | fuzzy-hair-man [ Tue Jul 05, 2005 3:56 pm ] |
big willy wrote: Yeah do it as a precaution.
Even though you can hold metal while you weld it (it doesnt carry any currnet), electrical bits could be effected if you don't unplug the battery first. Um I think there is current there it is just all going through the earth from the welder instead of using big willy as an earth ![]() ![]() Hence you stick your bum in the air whilst kneeling if you are caught in a electrical storm (and keep your head down) idea is that the lightning hits your bum and goes and earths out at your knees instead of hitting your head and sending current through your brain and heart, hence you are more likely to survive. |
Author: | awdmoke [ Tue Jul 05, 2005 4:27 pm ] |
Post subject: | Re: welding question |
benjamin wrote: do i need to unplug the battery when useing a stick welder on my car?
Yes. If not, you run the risk of: a) buring out your wiring loom & a possible fire b) destroying the diodes in your alternator c) blowing up (literally) your battery Not worth the risk when all you have to do is remove the earth clamp IMHO. Mike |
Author: | benjamin [ Tue Jul 05, 2005 5:28 pm ] |
all done removed the earth clamp tried welding but looks as if i need a oxy or mig as the stick wont weld thin metal anyway its tacked so all good ![]() |
Author: | sociallydisabled [ Tue Jul 05, 2005 10:25 pm ] |
i would reccomend mig ![]() |
