It is currently Tue Aug 19, 2025 6:02 pm
 Post subject: Fuel Manifold 12G2463?
PostPosted: Tue Dec 16, 2014 7:20 pm
Hi,
Need some assistance re fuel inlet manifolds. I have a set of twin 1 1/4 SU's to fit to my 1098 motor.
Will a 12G2463 fuel manifold be suitable for a 12G202 head? The head is not modified.
Also, what size needles should I be using in the SU's?
Thanks.
Dave
PostPosted: Tue Dec 16, 2014 7:31 pm
1098s with twin 1.25" SUs usually go well with either M or AH2 needles.
Any twin SU, 30deg manifold will be fine.
If it has location rings, the head's manifold face can easily be bored to 1-3/8" dia to fit these. Otherwise, align it with the ports then fit a couple of small dowels to locate it. Some locate on the studs, that works fine too.
[edit] angle added.
Last edited by drmini in aust on Wed Dec 17, 2014 6:30 am, edited 1 time in total.
PostPosted: Tue Dec 16, 2014 7:48 pm
It will be type that aligns with the port rings.
PostPosted: Wed Dec 17, 2014 8:13 am
Thanks for the advice. It does have location rings which are larger than the intake ports on the head. The rings can be removed so i might use small dowels to align it.
Just another question re SU needles. How do I know what needle is fitted to my SU's? Do they have markings to indicate what size they are?
Thanks.
PostPosted: Wed Dec 17, 2014 8:26 am
Yes, on the top end of needle that is inside the damper there should be a marking stamped.
Users browsing this forum: Sreedon and 86 guests
