Fuel Manifold 12G2463? https://www.ausmini.com/forums/viewtopic.php?f=2&t=88043 |
Author: | DCR [ Tue Dec 16, 2014 7:20 pm ] |
Post subject: | Fuel Manifold 12G2463? |
Hi, Need some assistance re fuel inlet manifolds. I have a set of twin 1 1/4 SU's to fit to my 1098 motor. Will a 12G2463 fuel manifold be suitable for a 12G202 head? The head is not modified. Also, what size needles should I be using in the SU's? Thanks. Dave |
Author: | drmini in aust [ Tue Dec 16, 2014 7:31 pm ] |
Post subject: | Re: Fuel Manifold 12G2463? |
1098s with twin 1.25" SUs usually go well with either M or AH2 needles. Any twin SU, 30deg manifold will be fine. If it has location rings, the head's manifold face can easily be bored to 1-3/8" dia to fit these. Otherwise, align it with the ports then fit a couple of small dowels to locate it. Some locate on the studs, that works fine too. [edit] angle added. |
Author: | Morris 1100 [ Tue Dec 16, 2014 7:48 pm ] |
It will be type that aligns with the port rings. |
Author: | DCR [ Wed Dec 17, 2014 8:13 am ] |
Thanks for the advice. It does have location rings which are larger than the intake ports on the head. The rings can be removed so i might use small dowels to align it. Just another question re SU needles. How do I know what needle is fitted to my SU's? Do they have markings to indicate what size they are? Thanks. |
Author: | timmy201 [ Wed Dec 17, 2014 8:26 am ] |
Yes, on the top end of needle that is inside the damper there should be a marking stamped. |
