It is currently Sat Jul 19, 2025 9:23 pm
PostPosted: Fri Dec 19, 2014 9:45 am
Hey guys, someone sent me a engine number that is 9FSA73.... it looks like a mk1 engine but the prefix for mk1 is 9FSAY. Could this be a different engine or is it more likely they have made a typo?
PostPosted: Fri Dec 19, 2014 9:51 am
this is the car. seems like a really good deal if its matching numbers and all.. so makes me suspicious lol
http://www.carsales.com.au/private/deta ... =8&sdmvc=1
PostPosted: Fri Dec 19, 2014 10:50 am
Not an engine number I am familiar with but this one has a 9FSA7 as well.
https://www.silverstoneauctions.com/196 ... r-s-1275cc
If the engine was a 1 litre I would say that the 7 was an upside down L
PostPosted: Fri Dec 19, 2014 10:53 am
Most likely a typo on the part of the owner, or he may be reading off a typo from the vehicle registry documents which is most common.
You can see it is a 1275 from the gap to the thermostat housing from the rocker cover as well as the extra bolts. You can also see there's a tappet cover breather if you zoom in as well, so its a Cooper S block which will correctly have a 9FSAY prefix if it is a Mk1. Alternately it may have been restamped with an error at one point after the block was decked, still, not much harm. The numbers may lie, but not the casting.
PostPosted: Fri Dec 19, 2014 11:47 am
viewtopic.php?f=27&t=87444
Discussed on here previously at least the price has come down !! ;-)
1972 Leyland Mini Clubman
2000 Honda CBR929RR
