rod change v remote pros and cons
https://www.ausmini.com/forums/viewtopic.php?f=2&t=88076
Author:  boomini [ Sun Dec 21, 2014 9:51 am ]
Post subject:  rod change v remote pros and cons
Hey guys trying to decide which gbox to build for my deluxe.
Having only ever had 1 remote box 15yrs ago I cant remember what it was like.
I like the idea of the remote change due to the torque tube effect of the housing.
Do rod change gear sets fit in a remote housing?
Cheers in advance
Rodney
Author:  drmini in aust [ Sun Dec 21, 2014 10:42 am ]
Post subject:  Re: rod change v remote pros and cons
Rodchange gearset complete fits in a 4 synchro remote case (22G1128). Except for reverse gear; the fork groove is different.
Remote box is better located than a rodchange, even without adding the rad end steady bar to it.
Rodchange has all the same location problems an 850 did.
Author:  boomini [ Sun Dec 21, 2014 12:52 pm ]
Cheers doc. Just the info I was after
Author:  jprior2912 [ Sun Dec 21, 2014 1:31 pm ]
Sorry to hijack this thread, but I've been meaning to ask for a while.
If you go with a remote shift gbox - if the outputs are hardy spicer - is it possible to convert to a pot joint set up with the remote gbox? If so, is it a big job/many mods?
James
Author:  drmini in aust [ Sun Dec 21, 2014 1:51 pm ]
James
Not hard at all- you just need to pull the diff, fit pot joint output shafts to it, and use common Mini (not S) side covers.
Author:  watto [ Tue Dec 30, 2014 12:30 pm ]
Gearboxes in both my Moke and work Mini are remote shift with pot joints.
No problems with oil leaks like I used to get from rod change (plenty of oil leaks everywhere else though :lol:)
More reliable than rubber unis or Hardy spicers.
I have had this set-up for nearly 20 years without problems.
