It is currently Fri Aug 01, 2025 8:50 pm
PostPosted: Sun Dec 21, 2014 9:51 am
Hey guys trying to decide which gbox to build for my deluxe.
Having only ever had 1 remote box 15yrs ago I cant remember what it was like.
I like the idea of the remote change due to the torque tube effect of the housing.
Do rod change gear sets fit in a remote housing?
Cheers in advance
Rodney
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Sun Dec 21, 2014 10:42 am
Rodchange gearset complete fits in a 4 synchro remote case (22G1128). Except for reverse gear; the fork groove is different.
Remote box is better located than a rodchange, even without adding the rad end steady bar to it.
Rodchange has all the same location problems an 850 did.
PostPosted: Sun Dec 21, 2014 12:52 pm
Cheers doc. Just the info I was after
Minis..
1975 van
PostPosted: Sun Dec 21, 2014 1:31 pm
Sorry to hijack this thread, but I've been meaning to ask for a while.
If you go with a remote shift gbox - if the outputs are hardy spicer - is it possible to convert to a pot joint set up with the remote gbox? If so, is it a big job/many mods?
James
PostPosted: Sun Dec 21, 2014 1:51 pm
James
Not hard at all- you just need to pull the diff, fit pot joint output shafts to it, and use common Mini (not S) side covers.
PostPosted: Tue Dec 30, 2014 12:30 pm
Gearboxes in both my Moke and work Mini are remote shift with pot joints.
No problems with oil leaks like I used to get from rod change (plenty of oil leaks everywhere else though :lol:)
More reliable than rubber unis or Hardy spicers.
I have had this set-up for nearly 20 years without problems.
Watto . :shock:
Photojournalist
Mini historian and enthusiast
