Are these S extractors?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=88169
Page 1 of 2
Author:  mitchell evans [ Wed Dec 31, 2014 1:06 pm ]
Post subject:  Are these S extractors?
Can someone please tell me if these are S extractors? they have been messed up a bit down the bottom
are they worth anything?
Thanks Mitch
Author:  9YaTaH [ Wed Dec 31, 2014 1:09 pm ]
Post subject:  Re: Are these S extractors?
Yep...Cooper, but there are exhausts that flow a lot better around these days...
I wouldn't think they would be worth much...
Author:  mitchell evans [ Wed Dec 31, 2014 1:11 pm ]
Thanks for that
Author:  1071 S [ Wed Dec 31, 2014 2:17 pm ]
For someone building an "original" S they may be priceless... Can't be too many that haven't been ditched.
Cheers, Ian
Author:  9YaTaH [ Wed Dec 31, 2014 7:40 pm ]
Priceless...
1. of inestimable worth; beyond valuation; invaluable
2. extremely amusing or ridiculous
Author:  Mick [ Wed Dec 31, 2014 10:45 pm ]
Also used on a couple of other cars with twins. Maybe MG 1100's?
They pop up, but when one wants them they're impossible to find! Ask winnabbey.
It's interesting to me that a pair of welded together steel pressings were cheaper and easier than formed tube which is the norm these days, but entirely reasonable for a company which pressed metal panels for a living.
Author:  Morris 1100 [ Wed Dec 31, 2014 10:51 pm ]
Yes, MG 1100, Cooper, Cooper S, Princess, etc. Most transverse A-series with twin carbs (except for the 1300GT) got those style of extractors.
There was a slight variation in the different models though.
Author:  drmini in aust [ Wed Dec 31, 2014 10:52 pm ]
MG1100 ones were same shape but different, a bit longer? I think.
The problem with all these pressings was they were thinner than a stock 1/16" wall zorst pipe.. so did not last well.
Author:  Aussie Brian [ Thu Jan 01, 2015 7:35 am ]
I still have a set tucked away somewhere as well, they came with my 70mk2 s. 8)
Author:  miniron [ Thu Jan 01, 2015 8:45 am ]
1275 S ones are 1/4" longer than others because the 1275 block is 1/4" taller than other blocks. 970 & 1071 S blocks are the same height as small bore 998/1098 blocks. Not sure about 997 blocks.
RonR
Author:  drmini in aust [ Thu Jan 01, 2015 8:54 am ]
997 blocks are just an underbored 998/1098 block.
I took one out to 68mm bore back in 1968.
Author:  mitchell evans [ Thu Jan 01, 2015 9:02 am ]
These are sold now
Author:  Mick [ Sun Jan 04, 2015 10:06 pm ]
Retro 'stractors!
Author:  Firefirey [ Mon Jan 05, 2015 7:26 pm ]
Mick wrote:
Retro 'stractors!
So Mick should they be grey or should they be matt black from original?
Regards Pete.
Author:  Mick [ Mon Jan 05, 2015 7:29 pm ]
These ones are now in winnabbeys hands. They were/are new old stock and are covered in a thick black enamel from the factory.
They weren't fitted to a car from new, so will leave the grey or black one alone as there may have been a different supply chain for the aftermarket.
