It is currently Sat Aug 02, 2025 7:05 am
PostPosted: Tue Jul 05, 2005 9:15 pm
High heel ninja
I have a bad knock in the front passengers side of my wifes clubman, i've replaced the lower control arm bushes, castor arm bushes are fine, i've spanner checked the whole front of the car, and the knock is still there, i knocks over any bump big or small.
Anybody got any ideas on it????
Doogie
Turns out it was the top shock mount lose, a 5 minute fix up, now she's all perfect again, my wifr is happy to drive it out to the swap meet on Sunday, WOO HOO
Doogie
PostPosted: Tue Jul 05, 2005 9:23 pm
here are some suggestions, some perhaps absurd
1. since the engine was out not long ago, is the problem inside the engine bay, engine mount, steady bar, loose attachment
2. it wouldnt be the wheels scuffing those bonsa flares of yours? (which indeed would make more of a scuffing sound)
Inconspicuously Conspicuous
PostPosted: Tue Jul 05, 2005 9:45 pm
High heel ninja
Nothing like that, it seems to be a compresion konck, wheels bearings & calipers are tight, basically i don't know :(
Doogie
PostPosted: Tue Jul 05, 2005 10:19 pm
:shock: OMG...Pops has the same thing!!!! Same side too!!!
I think mine is a stuffed knuckle joint. :?
PostPosted: Tue Jul 05, 2005 10:23 pm
Can't see it being much else than a knuckle really. Bugger all else in there to go wrong.
:idea: Make sure top of `strut' (same function as `trumpet' in dry cars) is located properly in displacer, before you pump it back up.. :wink:
PostPosted: Wed Jul 06, 2005 12:44 pm
Hi,
If it is hydrolastic, is your front hydro displacer lip located on the retaining bracket.
Thanks
PostPosted: Wed Jul 06, 2005 1:01 pm
I've had that with knuckles before, but I like Gezo's idea of checking if hydro bag is secure up there inside the subframe.
PostPosted: Thu Jul 07, 2005 6:27 pm
High heel ninja
All fixed now, lose top shock mouny. :D
Doogie
PostPosted: Thu Jul 07, 2005 7:04 pm
Ah... the infamous hydrolastic old age `optional extras..' :wink:
Worth having aren't they! :lol:
PostPosted: Thu Jul 07, 2005 7:18 pm
Do you reckon those shock absorbers make the suspension too stiff?
I reckon I need to soften mine up a little with the standard non-adjustable konis I've got fitted.
Maybe I'm just getting too old and fat.....
PostPosted: Thu Jul 07, 2005 7:22 pm
You don't want 'em hard. I run good old Pedders, been on there 10 years now and still work good! :wink:
<edit> all Konis are adjustable AFAIK, but you need to take off car, push to full bump and rotate the top part on the bottom.. it turns the valving.. :wink:
PostPosted: Thu Jul 07, 2005 7:44 pm
I had my suspicions about that, I had read too much saying that they were. I've been too lazy to try it though.
Maybe one day..... December looks free.....
