It is currently Mon Aug 04, 2025 8:05 pm
 Post subject: Part No.
PostPosted: Fri Jan 02, 2015 4:43 pm
Can someone tell me what car part no. 34703 blinker switch is for , mini or 1100 etc , thanks
 Post subject: Re: Part No.
PostPosted: Fri Jan 02, 2015 5:12 pm
It is for the 1100, it is the intermediate type with the green light but without the highbeam flasher. They didn't last long in production because they were very fragile, there was a service kit available to fix them at the time.
The main difference between a Mini switch and an 1100 switch is the 1100 switch sits on top of the column and a Mini one on the side of the column.
PostPosted: Fri Jan 02, 2015 7:10 pm
I thought so , could you use it on a mini?
PostPosted: Fri Jan 02, 2015 7:26 pm
You could use it on a Mini but you need the shroud from the 1100 because it has a hump on the top to clear the switch. (then the Mk1 steering wheel probably won't match the shroud)
The locating peg will need to be ground off the switch where it goes onto the column. (or drill a new hole on the column)
PostPosted: Fri Jan 02, 2015 7:40 pm
Thanks for that.!!
PostPosted: Fri Jan 02, 2015 8:09 pm
0R YOU CAN BUY A PROPER NEW ONE FROM US $60.00 EACH WE HAVE BOTH THE EARLY 2A6215 AND LATE 13H779 MINI INDICATOR SWITCHES PLUS MUCH MORE MINI ELECTRICAL PARTS ALL AT GREAT PRICES.
"Let us remove your "SHORTS"
PostPosted: Fri Jan 02, 2015 8:20 pm
Do you have a website?
PostPosted: Fri Jan 02, 2015 9:05 pm
http://www.ausmini.com/
PostPosted: Fri Jan 02, 2015 9:27 pm
or
http://www.ebay.com.au/sch/mini-electri ... 1543.l2654
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Sat Jan 03, 2015 11:51 am
Thanks guys for putting up the link., you guys are too quick for me with your computer skills.
PostPosted: Sat Jan 03, 2015 7:22 pm
Tony, I have bought a few parts from you in the past and I constantly tell people about you , However I have NOT bought the new indicator arms from you hopefully yours are of better quality than the reproductions available elsewhere I have 2 of these and they were not very successfull your electronic dizzy conversion kit is great.
Users browsing this forum: Bing [Bot], Phil 850 and 95 guests
