Part No. https://www.ausmini.com/forums/viewtopic.php?f=2&t=88187 |
Author: | AWOODY [ Fri Jan 02, 2015 4:43 pm ] |
Post subject: | Part No. |
Can someone tell me what car part no. 34703 blinker switch is for , mini or 1100 etc , thanks |
Author: | Morris 1100 [ Fri Jan 02, 2015 5:12 pm ] |
Post subject: | Re: Part No. |
It is for the 1100, it is the intermediate type with the green light but without the highbeam flasher. They didn't last long in production because they were very fragile, there was a service kit available to fix them at the time. The main difference between a Mini switch and an 1100 switch is the 1100 switch sits on top of the column and a Mini one on the side of the column. |
Author: | AWOODY [ Fri Jan 02, 2015 7:10 pm ] |
I thought so , could you use it on a mini? |
Author: | Morris 1100 [ Fri Jan 02, 2015 7:26 pm ] |
You could use it on a Mini but you need the shroud from the 1100 because it has a hump on the top to clear the switch. (then the Mk1 steering wheel probably won't match the shroud) The locating peg will need to be ground off the switch where it goes onto the column. (or drill a new hole on the column) |
Author: | AWOODY [ Fri Jan 02, 2015 7:40 pm ] |
Thanks for that.!! |
Author: | Convertible Mini [ Fri Jan 02, 2015 8:09 pm ] |
0R YOU CAN BUY A PROPER NEW ONE FROM US $60.00 EACH WE HAVE BOTH THE EARLY 2A6215 AND LATE 13H779 MINI INDICATOR SWITCHES PLUS MUCH MORE MINI ELECTRICAL PARTS ALL AT GREAT PRICES. |
Author: | cruiza [ Fri Jan 02, 2015 8:20 pm ] |
Convertible Mini wrote: 0R YOU CAN BUY A PROPER NEW ONE FROM US $60.00 EACH WE HAVE BOTH THE EARLY 2A6215 AND LATE 13H779 MINI INDICATOR SWITCHES PLUS MUCH MORE MINI ELECTRICAL PARTS ALL AT GREAT PRICES. Do you have a website? |
Author: | Morris 1100 [ Fri Jan 02, 2015 9:05 pm ] |
http://www.ausmini.com/ |
Author: | Scoop [ Fri Jan 02, 2015 9:27 pm ] |
or http://www.ebay.com.au/sch/mini-electri ... 1543.l2654 |
Author: | Convertible Mini [ Sat Jan 03, 2015 11:51 am ] |
Thanks guys for putting up the link., you guys are too quick for me with your computer skills. |
Author: | AWOODY [ Sat Jan 03, 2015 7:22 pm ] |
Tony, I have bought a few parts from you in the past and I constantly tell people about you , However I have NOT bought the new indicator arms from you hopefully yours are of better quality than the reproductions available elsewhere I have 2 of these and they were not very successfull your electronic dizzy conversion kit is great. |
